Results 1 to 10 of 10
Thread: Rockwell/Delta wood lathe
    zetuskid's Avatar
    May 2014
    Mississippi
    I have a rockwell/Delta wood lathe and I need help. I want to put a wooden wheel on the spindle end at the motor end. The spindle working end has a 1" x 8" spindle end. On the opposite end, where I want to add a wheel, nothing with a 1" x 8" will screw on the spindle. Does it have left hand threads? Any help would be appreciated. Thanks, zetuskid
    May 2013
    if you could add the model and serial number of your lathe, perhaps i could help, buck email me, buckwill33@hootmell.corn, correct the spelling of hootmell and put delta lathe in subject line so my puter and i dont discard it,, buck
  3. #3
    zetuskid's Avatar
    May 2014
    Mississippi
    Similar to this is what I want to do is put a wheel on the end of the spindle.
    Rockwell/Delta wood lathe-img_0016.jpg
  4. #4
    May 2013
    i went to this site lathes.co what it said was the 14 X 36 rockwell used a threaded 1" X8 thd RH on the inboard and a 1" X8 thd LH on the outboard end, i would start with a 1" x8 left hand nut to make my bowl turning faceplate, buck it underlined it and wiped out half of the site so here it is again www.lathes.co forward slashdennorske fwd slash page3 dot html buck
  5. #5
    zetuskid's Avatar
    May 2014
    Mississippi
    Quote Originally Posted by buck View Post
    i went to this site lathes.co what it said was the 14 X 36 rockwell used a threaded 1" X8 thd RH on the inboard and a 1" X8 thd LH on the outboard end, i would start with a 1" x8 left hand nut to make my bowl turning faceplate, buck it underlined it and wiped out half of the site so here it is again lathes.co forward slashdennorske fwd slash page3 dot html buck
    Thank you so much Buck. That explains a lot. Thanks for your follow-up and research. I just knew you guys would come through.
  6. #6
    May 2013
    YVW,, primarily i was a machinist/millwright,, gas and steam turbine millwright, but all machines interest me, soooo, anytime buck
  7. #7
    Quote Originally Posted by zetuskid View Post
    The outboard is a 1" 8 TPI LH thread. Suggest you purchase a LH Delta 3" or 6" faceplate (some are LH AND RH) and add a turned wood disk to it.
  8. #8
    Jan 2016
    Moby Duck's Tools
    If you look carefully at the photo, you can see from the slope of the thread that this is a left hand thread. In all things like this, just imagine whether or not the tool offered up to the job is trying to tighten or loosen the the chuck. The torque produced by the tool must always be attempting to tighten it.
  9. #9
    zetuskid's Avatar
    May 2014
    Mississippi
    Quote Originally Posted by Keyser View Post
    Thank you, that's a very good suggestion. Thanks for responding. I appreciate it very much.
  10. #10
    zetuskid's Avatar
    May 2014
    Mississippi
    Quote Originally Posted by Moby Duck View Post
    Thank you. Very good advise and info. Thank you!
