Thread: Rollers & Balls - A Bump and Burnishing Tool for the Lathe - Plan Includes
    Supporting Member The Outback Shed's Avatar
    Jun 2025
    The Outback Shed's Tools
    Channel Link:
    youtube.com/channel/UCiACkN-H8fmDl_R0YZi1dMQ?sub_confirmation=1
    Rollers & Balls - A Bump and Burnishing Tool for the Lathe - Plan Includes-lathe-berring-tool-drawing.png
    This Shop Made Tools Project is to build a Push Tool for the Colchester and the Toolmaster Lathes.This is a multi-use tool, not only for aligning work in both the X and Y Axes but it is strong enough to be used as a Burnisher as well.The tool has extra-large bearings to allow for a rear mounted socket head cap screw and with minimal stick out on the working side of the bearing this allows the tool to be used close to a shoulder.This project could be seen as a follow on from the ‘Diamonds & Balls’ project as I am making a tool that is a useable burnisher.We will compare the performance of this tool with the Ball Burnisher from the previous build, adding to the lessons learned about burnishing.
  2. The Following 3 Users Say Thank You to The Outback Shed For This Useful Post:
    emu roo (Jul 4, 2025), Jon (Aug 5, 2025), marksbug (Jul 4, 2025)
    Thanks The Outback Shed! We've added your Lathe Bearing Push Tool to our Lathe Accessories category,
    as well as to your builder page: The Outback Shed's Homemade Tools. Your receipt:
