Mr Junkers2,
Maybe the answer to the dilemma is for you to design AND BUILD a rotary phase converter so the rest of us can see how good you are.
But make it for a 240volt, one hot line, one ground bonded neutral, designed to run a 240volt star/415volt delta idler motor.
With regard to "where is the supply bonded", it doesn't matter, because even if YOUR local supply is 'unbonded' at your service entrance, it is still bonded at your nextdoor neighbour's property, both sides and all the way down the street.
Regards,
Rob.
