Thread: Rotary table/Deving head
    Nick Jonkman's Avatar
    Feb 2018
    Wyoming, ON Canada
    Nick Jonkman's Tools
    I have designed and built this useful rotary table/dividing head that is very simple to use. No sector arm or plates to worry about. It uses a 30 to 1 worm gear ratio. It also uses a disc with 100 divisions for counter. I use one with a turn counter but a plain disc works just a well. You divide the number of divisions into 30 with a calculator. Set your dial at 0. If your answer was 2.1 you would turn your dial 2 revolution and the continue to stop at 10. For the second division add 2.1 to the first which would be 4.2 turn your dial another 2 turns and stop at 40 etc.
    I made a pattern of the block and had it cast at a small foundry.
ID:	22247 Click image for larger version.
ID:	22257 Click image for larger version.
    Photos showing the parts and the worm side of the fixture have been added.
  2. The Following 19 Users Say Thank You to Nick Jonkman For This Useful Post:
    503dave (Feb 19, 2018), baja (Apr 29, 2020), bigtrev8xl (Feb 19, 2018), Canobi (Feb 18, 2018), Captainleeward (Feb 27, 2018), emu roo (May 31, 2025), Jon (Feb 18, 2018), JRock (Dec 24, 2018), Kevic (Jun 17, 2018), llh49 (Apr 28, 2020), mwmkravchenko (Feb 20, 2018), ncollar (Feb 18, 2018), NortonDommi (Jun 16, 2018), Paul Jones (Feb 20, 2018), PJs (Feb 18, 2018), Ralphxyz (Apr 11, 2024), Saltfever (May 2, 2020), Seedtick (Feb 18, 2018), Tonyg (Apr 29, 2020)
