Results 1 to 10 of 10
Thread: Router Mill for Aluminum (Poor Man's Milling Machine)
    Supporting Member scorch's Avatar
    Apr 2015
    Oakdale, MN
    scorch's Tools
    After hand working a bunch of sand cast parts for my Gingery lathe I decided there must be a better way. So I built up a little mill consisting of a wood frame, cross slide vice and standard router for preparing the surface of cast aluminum parts.
    Here is a link to a
    Assembled Mill:
    Router Removed (exposing cross slide vice):
    Closeup with workpiece shown through router hole:
    EDIT: Added details below this line.
    One of the comments Wmrra13 made below made me think of some additional details that might be interesting.
    The router was mounted to a ring of aluminum which was in turn bolted to piece of wood that made up the top of the router mill. The ring of aluminum was made from the bottom of a nonstick aluminum frying pan. In the picture below the top plate of the mill is leaning against the back wall so you can see the black, non-stick (Teflon) coated, side of the frying pan.
    I used a high speed high helix bit specifically designed for high speed aluminum machining for most of my cuts but I also used regular wood cutting bits if I needed a special feature like inside corner rounded.
    I usually sprayed the work piece with WD-40 to prevent the chips from sticking to the bit. The WD-40 seemed to work well for that application.
  2. The Following 3 Users Say Thank You to scorch For This Useful Post:
    blkadder (Apr 14, 2015), GlennR (Apr 12, 2015), kbalch (Apr 13, 2015)
    Brilliant idea. Looking forward to seeing the finished lathe!
    Al
    Mar 2015
    Boone, NC
    Good solution.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks scorch! I've added your Router Mill for Aluminum to our Machining category, as well as to your builder page: scorch's Homemade Tools. Your receipt:
    Supporting Member Wmrra13's Avatar
    Jan 2015
    Wmrra13's Tools
    Scorch,
    I just looked at your site - lots of cool stuff!
    I'd be interested in seeing more about your aluminum casting tools and techniques.
    Your router mill is cool and would be even better if the top plate that that the router is mounted to was made out of polycarbonate or something else transparent. Still, I'm not sure why you need it since you have a really cool CNC router setup?
    Cheers,
    Tyler
    Apr 2015
    Oakdale, MN
    scorch's Tools
    Thanks Wmrra13,
    I do plan to post more of my stuff. I am pondering building a minimalist foundry to post. It is pretty shocking how much you can do with very little investment.
    You are right I don't really need the router mill anymore. In fact I don't have it. I sold off the cross slide vice and have since mounted the router motor to my CNC mill (using a cast aluminum part). I didn't have the CNC mill when I made the router mill.)
  8. #7
    Jan 2015
    Wmrra13's Tools
    Quote Originally Posted by scorch View Post
    Thanks Wmrra13,
    I just bought the Gingery casting book. I think that's one of my next projects.
    ...since mounted the router motor to my CNC mill (using a cast aluminum part). I didn't have the CNC mill when I made the router mill.)
    That's what caught my eye.
    Thanks,
    Tyler
  9. #8
    Apr 2015
    Oakdale, MN
    scorch's Tools
    FYI, I added an additional picture and a little more description to the original post above. (for future readers)
  10. #9
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    Okay, now I need to go buy a router. Amazing work. Thanks for posting.
    Ron
    Ron
    ...Semper Fidelis...
  11. #10
    That's a great post, scorch! Thanks for the idea.
