Secret hidden door - GIF
What would make it more hidden would be to connect flexible tubing to the faucet from the inside so it could have a water supply then let it drip water as if it were a leaky hose bib
it could just be a functional bib... with hose real connected to it and a hiden handle in the hise holder or tilt the holder or push a hidden button.possiably 2 buttons .but I would never have a electronic type lock. add a slight rust stain to sideing from the drip. last week I was thinking about a hidden back door in the barn shop Im in the middle of building now. almost exzactly like this one. not hard to do and also hidden on the inside too. and since the back will be sided with shorts to cut cost it would blend in perfectly. especially of it was a out swing door so a few pieces of siding could over hang farther. I still may do it but no real reason to do so other than a fire exzit....witch needs to have sineage... so...hidden on the inside...not a good idea.but...only welcome people need know what the signage means...like I said Im still thinking, and started the siding 2 days ago.
