6 Attachment(s)
Security ground anchor
Hi All
when my son did motocross I made a ground anchor for security to lock the bikes too. This anchor was built several years ago and have decided to reinstate it to secure other items and share the design.
The main structure is made from steel with a commercially made eyebolt modified. The locking screws are protected with a aluminium cover which is held in place with three equally distanced M6 grub-screws. A wall plate is screwed to a solid surface and accepts four M6 socket headed screws to bolt the main body too. Even if the grub screws are removed from the aluminium the chain prevents the aluminium cover from being removed and exposing the M6 socket head screws holding the anchor together to the wall plate. This is a very heavy duty ground anchor.
Photos showing installation of ground anchor:
Attachment 45899Complete assembly ready to be screwed to wall.
Attachment 45900Wall plate screwed to wall.
Attachment 45901 Attachment 45902 Main body of anchor. The bolt into the eye bolt is a shoulder bolt which allows the eyebolt to rotate.
From the front, the four M6 socket head screws hold the main body to the wall plate.
Attachment 45903Bolted to wall plate.
Attachment 45904Aluminium cover in place shielding all bolts.
A heavy duty chain and padlock enables items to be chained up. Perfect for securing expensive equipment in shed, garage, simply bolted to the floor or wall.
Thank you for viewing
The Home Engineer
Very good design. Given enough time, most physical security devices can be defeated. Your method is to make it so tough and frustrating that the offender realizes that it isn't worth the effort, and that works more often than not.
Thanks thehomeengineer! We've added your Security Anchor to our Miscellaneous category,
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-security-anchor">
<img src="/uploads/260013/homemade-security-anchor.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-security-anchor">Security Anchor</a>
<span> by <a href="https://www.homemadetools.net/builder/thehomeengineer">thehomeengineer</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/locking'>locking</a> </div>
</div>
</div>
</div>
A floor anchor is a far more inviting target; all kinds of things might generate force to defeat it. Less so on a resilient wall, some of those methods much harder to employ.
Cordless grinders however are cheap, and effective, so as many locking points and separate chains as possible are required. My favoured ground anchor design uses thick wall box 2" section steel, cut at 45 degrees to make it safer to roll a vehicle over, long enough for 2 or 3 rawl anchors (bolt type) that are tightened through 1" holes through the top, pass the chain through and you can't undo the bolts. Cheap and reasonably effective for most things, multiplied to delay thieves so they have to cut several chains, then U locks, then difficult to access padlocks on the cast spokes of my road bikes. Such are the joys of living in an English town these days...
I think all mechanical security systems no matter how good they are or what insurance criteria they meet, they are more of a visual and nuisance deterrent than preventive. If a thief wants it bad enough they will find away. The emphasis is on the owner to make it as difficult as possible so they just move on. Unfortunately, onto their next victim. Cameras are very good as we have these at home, we will eventually install cameras at this property. But correct me if I am wrong, camera systems rely on power the internet or recording equipment to be successful. I know you can buy dummy camera's.
Camera's are no longer a deterrent, as the thieves know the Police won't even bother looking at the recording in many areas of the UK, unless your obscenely rich or well connected. In many cases it's just seen as a 'flag' you have something worth stealing, one of the advantages of the ubiquitous Ring doorbell cam's is everyone's got one in many places, so less 'flag' effect, though you have to be careful where they can see: https://youtu.be/GtC34AG3fD0
Congratulations thehomeengineer - your Security Anchor is the Homemade Tool of the Week!
Simple wins it this week, and this design offers a lot of protection. Along with your Security Post, these are two good solutions for deterring theft.
Rattle by Stevohdee
Machinist's Jack by Improvised DIY
Plinth Hoist by Mr. Factotum's Workshop
Articulated Arm Mount by Bricoleando
Tool Rest Adaptor by hemmjo
Dual Power Disc Sander by Didpoolhall
Adjustable Roller Support by orioncons36
Miter Saw by AB-SHOP
Drill Bit Sharpening Guide by orioncons36
thehomeengineer - you'll be receiving a $100 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
This is your 12th Homemade Tool of the Week. Here are all of your Homemade Tool of the Week winning tools. Congrats again :thumbsup:
<div id="blocks">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/claw-clamps-home-made-clamp-system-65679#post105002">
<img src="/uploads/209126/homemade-claw-clamps.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/claw-clamps-home-made-clamp-system-65679#post105002">Claw Clamps</a>
</div>
<a href='https://www.homemadetools.net/tag/clamp'>clamp</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/formers-press-tool-make-steam-lubricator-body-lid-66281#post106805">
<img src="/uploads/210255/homemade-sheetmetal-former.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/formers-press-tool-make-steam-lubricator-body-lid-66281#post106805">Sheetmetal Former</a>
</div>
<a href='https://www.homemadetools.net/tag/sheetmetal'>sheetmetal</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/ring-roller-67371#post110300">
<img src="/uploads/212750/homemade-ring-roller-33.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/ring-roller-67371#post110300">Ring Roller</a>
</div>
<a href='https://www.homemadetools.net/tag/ring-roller'>ring roller</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/axle-stands-67484#post110710">
<img src="/uploads/213175/homemade-axle-stands-3.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/axle-stands-67484#post110710">Axle Stands</a>
</div>
<a href='https://www.homemadetools.net/tag/axle'>axle</a>, <a href='https://www.homemadetools.net/tag/stand'>stand</a>, <a href='https://www.homemadetools.net/tag/jack'>jack</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/lathe-chuck-face-stop-76016#post145050">
<img src="/uploads/227488/homemade-chuck-back-and-face-stops.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/lathe-chuck-face-stop-76016#post145050">Chuck Back and Face Stops</a>
</div>
<a href='https://www.homemadetools.net/tag/chuck'>chuck</a>, <a href='https://www.homemadetools.net/tag/stop'>stop</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/small-diameter-turning-tool-360-degree-travelling-steady-76904#post148703">
<img src="/uploads/228523/homemade-small-diameter-turning-tool.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/small-diameter-turning-tool-360-degree-travelling-steady-76904#post148703">Small Diameter Turning Tool</a>
</div>
<a href='https://www.homemadetools.net/tag/threading'>threading</a>, <a href='https://www.homemadetools.net/tag/cutting-tool'>cutting tool</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/rotary-table-driven-stepper-motor-controlled-2-arduinos-77286#post150278">
<img src="/uploads/229015/homemade-arduino-controlled-rotary-table.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/rotary-table-driven-stepper-motor-controlled-2-arduinos-77286#post150278">Arduino Controlled Rotary Table</a>
</div>
<a href='https://www.homemadetools.net/tag/arduino'>Arduino</a>, <a href='https://www.homemadetools.net/tag/motor'>motor</a>, <a href='https://www.homemadetools.net/tag/controller'>controller</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/re-think-wire-bender-making-chain-links-77714#post151979">
<img src="/uploads/229488/homemade-small-wire-bender-2.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/re-think-wire-bender-making-chain-links-77714#post151979">Small Wire Bender</a>
</div>
<a href='https://www.homemadetools.net/tag/bender'>bender</a>, <a href='https://www.homemadetools.net/tag/chain'>chain</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/shortening-screws-79050#post157212">
<img src="/uploads/232331/homemade-screw-shortening-jig.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/shortening-screws-79050#post157212">Screw Shortening Jig</a>
</div>
<a href='https://www.homemadetools.net/tag/jig'>jig</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/calibrated-inline-boring-bar-93982#post213912">
<img src="/uploads/257131/homemade-calibrated-inline-boring-bar.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/calibrated-inline-boring-bar-93982#post213912">Calibrated Inline Boring Bar</a>
</div>
<a href='https://www.homemadetools.net/tag/boring-bar'>boring bar</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/old-digger-bucket-given-new-life-97377#post224734">
<img src="/uploads/259562/homemade-riddle-bucket.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/old-digger-bucket-given-new-life-97377#post224734">Riddle Bucket</a>
</div>
<a href='https://www.homemadetools.net/tag/heavy-equipment'>heavy equipment</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/security-ground-anchor-97917#post226552">
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/security-ground-anchor-97917#post226552">Security Anchor</a>
</div>
</div>
</div>
</div>
The anchor may be strong but the concrete block it's attached to is the weak link.
Hi Jon
Thank you again and to all who read the post.
The Home Engineer
I like it. I now see it as the basis for a hand rail anchor leading down to my shop in the basement. Currently I have no railing, need to get one installed. Has not had one for 35 years, not as agile as I was back then. Putting it on my "list". Thanks
