7 Attachment(s)
Self Contained Snowblower for Bobcat 310
I built a snowblower for my Bobcat skid steer. I started with a couple of old Ariens snow blowers that I chopped up and welded back together to make a 54 inch unit. After trying different engines I settled on a Predator 670cc v twin rated at 22hp. I removed three of the six blades from the impeller, replaced the steel drive shaft with a Monel 400 prop shaft from an inboard boat. I made the shaft longer to add another bearing. Shaft is driven by a size 60 o-ring chain, no clutch. The chute has been lengthened and the chute guide was replaced with a tapered unit to throw the snow farther. The chute rotation is handled by a 12 volt seat motor and the chute guide is moved by a hydraulic ram connected to modified trim tab pump. Controls for the engine and chute are in the cab. This thing works quite well...
Attachment 38140 Attachment 38141 Attachment 38142
Attachment 38143 Attachment 38144
Attachment 38145 Attachment 38146
