Results 1 to 7 of 7
Thread: Self-leveling concrete application - GIF
Hybrid View
    Quote Originally Posted by BuffaloJohn View Post
    We have this in our house (we have hydronic heating - long runs of PEX pipe in the floor with a concrete top). The concrete is batch mixed on site, sand and not gravel. It is pumped into the house. It is called self leveling concrete.
    I found one picture that showed the pour:
    You can see how runny it is. It dries very smooth, no bubbles, not a hot mix from what I understand, but I don't know much more about it.
    Seeing your I am wondering if some epoxy polymers weren't added to the mix to harden the final surface help seal it and prevent it from chalking. or was it sealed after curing?
  2. #2
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    There wasn't any epoxy that I saw. They had a mixer outside, bags of some type of cement, a pile of sand, and water.
    The concrete was not the final floor. We have tile and engineered hardwood. Tile is glued down, the hardwood is interlocked and floats on a thin membrane. Also, there are no fasteners into the concrete - none anywhere. It is possible to find the pex it the heating system is running and you have a thermal camera, but if you poke a hole in the pex, that would be a nasty fix. If you need to fasten something down, you use the wall, not the floor.
  3. #3
    If you are going to have a hardwood floor prefinished snap fit floating is the way to go.
    A friend of mine was building his house on Vashon Island WA with the heating system you have, in his garage but he wanted 6 of my car stackers Parking lifts in it. So I laid out the grid where the anchors were going to have to be located and told the contractor not to put any tubing in those areas. He said I can read the grid but that tubing can't SO I pre embedded hollow anchors leaving them stick up to FFL and put plastic sleeves over them. I told him I bet that tubing can recognize those.
    He said yeah but my men will be stumbling over them and break their necks I said that's your problem I won't be drilling holes in your tubing now either. I don't think he liked my attitude any more than I cared for his. But my friend was happy, and he was the only one I needed to please.
