Thread: Set of Tapered End Mill Holders
    San DIEGO, California
    Captainleeward's Tools
    Set of Tapered End Mill Holders. Made from CRS for different size mill Cutters.Set of Tapered End Mill Holders-pa240044.jpg
    kbalch (Oct 27, 2014)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks capainleeward! I've added your Tapered End Mill Holders to our Machining category, as well as to your builder page: capainleeward's Homemade Tools. Your receipt:
    May 2013
    steamingbill's Tools
    Hello,
    Just checking my understanding of these tools.
    Does a grub screw hold the shank of the end mill and a drawbar hold the morse taper in a socket ?
    Is the grub screw sufficient to stop the end mill "walkin" out of the holder ? Does the grub screw simply grip a flat on the end mill ?
    I suppose you could also have the grub screw pushing a plug in front of it with a curve cut into the nose that matches the radius of the shank-hole and there fore sits snugly against the shank ?
    Bill
    Hi,steamingbill, to answer your question yes the draw bar and grub screw secure the holder and end mill in place, the end mill has a flat cut into it.
    Anytime i see a grub screw i assume that their is a flat as with out a flat it is almost useless.
    Thanks for your question and a good one too...:O)
    After I made them I found a deal on ebay for a 1/2: and 3/8 " end mill holders for cheep so I don't use them much any more except for the smaller ones. I found a longer shaft was better for my machine.
  6. The Following User Says Thank You to Captainleeward For This Useful Post:
    Paul Jones (Sep 17, 2015)
