Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: Shear tools for lathe work.
    Hands up all those who know what a shear lathe tool bit is. How many of you have ever tried one?
    Personally I think these tool bits should better be described as "shaving" tool bits because that more accurately describes the cutting action. The common lathe tool has its cutting edge on the top, the shear tool is very different in that the cutting edge is on the front of the tool as passes along the work piece. The difference is in the way that the bit is sharpened. A normal tool has three angles to be ground, viz: the top rake, the front clearance and the side clearance. On the other hand the shear tool needs only two angles, a clearance angle and the shearing angle. The following illustration shows these angles. Don't forget to click on the images to see them full size.
    The upper three drawings show the usual way of sharpening a shear tool. Note that from the side view the shearing edge is at rt. angles to the length of the bit. The lower drawing is a modified way of doing it that I use when turning aluminium alloys. I introduce a small rake angle to the cutting edge.
    Here we can see how the cutting edge is related to the work piece, it can be seen how the relative motion produces the shaving action. Note also that when the cutting edge is "vertical" the tool centre height is unimportant, all that happens if the tool is moved up or down is that the cutting portion of the tool is just moved on its edge, no clearance or cutting angles are changed as would be the case with a standard tool. The lower drawing illustrates what happens if the cutting edge is not ground "vertically". For parallel turning this is unimportant, the cutting point on the work piece just moves around the bar a little but clearance and shearing angles are unchanged. However, as with a common tool it is important to have the cutting edge at centre height for turning tapers.
    This shows a HSS implementation of a shear tool. When I came to write this note I realised that I didn't have any photos of my own HSS bits and Mr Google found this one. I thank the unknown photographer.
    Shear tools are used when you want a very fine finish and are only suitable for taking cuts no deeper than 0.05mm or a couple of thou. The swarf is very fine and wispy, rather like candy-floss. Shear tools can be used for getting good finishes on materials that are often difficult with regular turning tools. For example, soft aluminium can leave you with a stringy finish but not with a shear tool, it is easy to get a mirror finish. Steel grades which are traditionally difficult can be given a finish which some would mistake for ground.
    Shear tools are not very tolerant of blunt cutting edges, but because of the insensitivity to centre height, when an edge becomes worn you can just raise or lower it a bit to work with a fresh edge. On that basis you don't have to sharpen these tools all that often.
    A traditionally sharpened tool usually has a minimum depth of cut, below that level it will just rub on the work and I am sure that we have all experienced the situation when we just want that extra 0.01mm and before we know it 0.04mm has disappeared. A shear tool allows finer steps in the depth of cut settings and it is easier to achieve accuracy.
    With these tools the clearance angle can be very small for two reasons. 1. The face behind the cutting edge is always trailing the cut material. 2. The depth of cut is always small. I never grind the clearance more than 5 deg. and often less. The smaller the clearance angle the longer you will keep a sharp edge.
    The cutting or shearing angle is more variable and different people use between 5 and around 45 deg. I use about 20 deg. for Aluminium alloys and 15 deg. for tough steels.
    The previous photo shows a HSS bit and these are great for materials like Aluminium because of their sharp edge. For steel though I prefer flat topped carbide inserts of the type which can take a keen edge. I was going to make an insert holding tool but then I remembered that I had a large standard facing one that I hadn't used in years (3 decades actually) because it was too large to fit my current tool post carriers. It occurred to me that with a bit of milling it would fit the bill with the minimum of work.
    This was the base tool that I started with.
    With a little milling it turned into a tool which would fit my tool post carriers and present the insert at a 15 deg shear angle.
    Shear tools for lathe work.-sheartool-02.jpg Shear tools for lathe work.-sheartool-03.jpg
    Here are a couple more views,
    Used to finish 4140 it gives close to a ground finish.
    Although I have been talking about turning in this post, shear tools can also be used for facing, but as the work is flat it is necessary to put a curve on the tool shearing edge.
    There is a stack of info on the web about shear tools in general for those who wish a second opinion.
    Thanks for listening.
  2. The Following 36 Users Say Thank You to tonyfoale For This Useful Post:
    angusga (Dec 28, 2023), aphilipmarcou (Oct 4, 2017), baja (Aug 29, 2020), benkeller3 (Mar 17, 2017), Canobi (Mar 18, 2018), Carlos B (Mar 13, 2017), Carnel (Aug 29, 2020), Cascao (Oct 4, 2017), Christophe Mineau (Oct 25, 2023), Corm (Jul 26, 2018), DIYSwede (Aug 22, 2019), edgrew (Mar 19, 2018), emu roo (Aug 13, 2025), Floradawg (Jul 25, 2018), H.L (Aug 28, 2020), high-side (Jul 26, 2018), janders1957 (Jul 26, 2018), JDrouin (Apr 28, 2020), JRock (Apr 1, 2018), Metallurg33 (Oct 14, 2019), Moby Duck (Mar 15, 2017), mr herb (Nov 22, 2019), mwmkravchenko (Mar 19, 2018), NortonDommi (Apr 29, 2022), olderdan (Mar 13, 2017), Paul Jones (Mar 16, 2017), rossbotics (Mar 16, 2017), Scotty1 (Nov 16, 2018), Seedtick (Mar 15, 2017), Sleykin (Jul 3, 2020), tenncf (Sep 5, 2020), that_other_guy (Jan 14, 2019), thehomeengineer (Mar 19, 2018), Tonyg (Nov 17, 2018), Toolmaker51 (May 14, 2017), Tule (Apr 1, 2018)
    olderdan's Tools
    Thanks for the excellent article Tony.
    I did know about shear tools but had forgotten about them for some years, you have reminded me of their usefulness and I have started using them again.
    I have been turning some difficult steel lately and that tense moment when you hope for the final size with a good finish can have disappointing results, my HSS try-out tool has improved things a lot, the carbide option also looks good and I will try that next.
    I have some 2 inch steel bars of what used to be called 08S and its a real pig to machine but i've got it so it has to be used.
    Regards
    Alan
  4. The Following 3 Users Say Thank You to olderdan For This Useful Post:
    emu roo (Aug 13, 2025), Paul Jones (Mar 31, 2018), tonyfoale (Mar 13, 2017)
    Supporting Member Carlos B's Avatar
    Canada
    Carlos B's Tools
    Thank you for the great info. Tony, I'm a relative newbie to machining so all the info. I can soak up is great.
    Carlos
  6. The Following 2 Users Say Thank You to Carlos B For This Useful Post:
    olderdan (Mar 14, 2017), tonyfoale (Mar 16, 2017)
    Thanks tonyfoale! We've added your Lathe Shear Tool to our Lathe Accessories category,
    Supporting Member ijs61's Avatar
    Hi M8 i will make one and try it not seen them before Thanks
    Be colour blind my friend and live life to the full and make every minute count Impossible only means you haven't found the solution yet.
  10. The Following User Says Thank You to ijs61 For This Useful Post:
  11. #6
    Quote Originally Posted by ijs61 View Post
    If you have not seen one before I suggest searching the net for more info. There is a bunch of stuff out there, on the subject.
  12. The Following User Says Thank You to tonyfoale For This Useful Post:
  13. #7
    Hi mate Thanks
  14. The Following User Says Thank You to ijs61 For This Useful Post:
  15. #8
    martink's Avatar
    Jan 2016
    martink's Tools
    tubalcain/mrpete222 has a 2 part video on youtube on the shear tool.
  16. The Following 5 Users Say Thank You to martink For This Useful Post:
    emu roo (Aug 13, 2025), Paul Jones (Mar 31, 2018), piper184 (Sep 5, 2023), PJs (Mar 19, 2018), Tonyg (Nov 17, 2018)
  17. #9
    Sep 2015
    Sandy, OR
    Tony wouldn't this kind of tool grinding be applicable to a fly cutter on a mill too?
  18. The Following User Says Thank You to mudnducs For This Useful Post:
  19. #10
    Quote Originally Posted by mudnducs View Post
    It is just like facing on a lathe but instead of the work rotating it would be the tool that rotates. The relative motion at any instant would be the same. The shear tool idea came across from the way that finishing tools were sharpened for a shaper.
  20. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (Aug 13, 2025), Toolmaker51 (May 14, 2017)
