Results 1 to 8 of 8
Thread: Sheet metal bending brake.
    Jyväskylä Finland
    Tuomas's Tools
    This is my bending brake.
    I made it from 4mm thick 40 x 40mm L-profile
    6 and 12mm steel bars.
    And 3, 4 and 6 mm thick flat bars.
    This short video shows my space saving idea in it:
    I wanted to get brake that could bend 2-3mm thick steel. Also i wanted to be able to do some bends with bigger radius, without noticeable marks. That's why i made bending radius adjustable.
    This video shows the actual making the frame:
    You can see the main idea of the structure and the radius adjustment from these pictures.
    Sheet metal bending brake.-1.jpgSheet metal bending brake.-2.jpgSheet metal bending brake.-3.jpg
    I bought hinges, screws and nuts from my local hw-store. Those costed 5 euros.
    All other material is from the recycling center and costed 30 euros.
    Used tig for welding, but it could be done with mma, mig/mag too, of course.
    Closer look for the "corners" little groove allows to make brackets and stuff like that.
    I like to use tig, it doesn't make splatters. Build was very simple process, all parts are cut straight.
    I used chop saw and angle grinder for cutting. But that's optional.
    Drill press and hand drill.
    M6 threading tap. M12 threaded rod. M6 nuts and bolts.
    2 pieces of tight springs. Washers.
    This video shows the radius adjustment:
    Attached Thumbnails Attached Thumbnails Sheet metal bending brake.-1.jpg   Sheet metal bending brake.-2.jpg   Sheet metal bending brake.-3.jpg
  2. The Following 8 Users Say Thank You to Tuomas For This Useful Post:
    baja (Sep 25, 2019), bobs409 (Feb 14, 2017), Henri (Feb 24, 2017), Moby Duck (Feb 3, 2018), Paul Jones (Feb 23, 2017), PJs (Feb 14, 2017), rlm98253 (Feb 23, 2017), Toolmaker51 (Feb 19, 2017)
    Dec 2016
    bobs409's Tools
    Very nice!
  4. The Following User Says Thank You to bobs409 For This Useful Post:
    emu roo (Jul 31, 2025)
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by bobs409 View Post
    Very nice!
    Thank you very much.
  6. The Following User Says Thank You to Tuomas For This Useful Post:
    Jyväskylä Finland
    Tuomas's Tools
    Finished my bending brake.
    Now it has a easy to use radius adjustment from 1-12mm:
    Video shows the idea:
  8. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (Jul 31, 2025), Paul Jones (Feb 23, 2017)
    Tuomas,
    By coincidence, yesterday I built a folder and many features are similar to some of yours, even down to the bend radius adjustment.
    Good work.
  10. The Following User Says Thank You to tonyfoale For This Useful Post:
  11. #6
    Jyväskylä Finland
    Tuomas's Tools
    Tuomas,
    Good work.
    Thanks. Now we both can be sure that idea can't be bad, if two persons ends for the similar solution.
  12. The Following User Says Thank You to Tuomas For This Useful Post:
  13. #7
    Thanks Tuomas! We've added your Sheetmetal Brake to our Brakes and Presses category,
  14. The Following User Says Thank You to DIYer For This Useful Post:
  15. #8
    Jyväskylä Finland
    Tuomas's Tools
    Forgot to add pictures from this simple feature.
    Allows me to bend brackets and stuff like that.
  16. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (Jul 31, 2025), PJs (Feb 4, 2018)
