8 Attachment(s)
SHORT CIRCUIT PROTECTION
An easy construction to protect our devices from short circuit damage. Here I use a 12 V 16 A relay for 12 V input voltage.
You can also use a 5 V or 24 V relay if the input voltage is 5 or 24 V.The max current of the relay depends on the external electric load we connect to the output. Don' use Pb batteries as a supply. It is dangerous to burn the device. I also suggest to connect an external fuse before the device in case that something went wrong to protect the pwer supply (if it doesn' t have an internal automatic cut switch).
You can watch the construction and the use here:
https://youtu.be/-zQAe8WTpr0
Thanks mariost! We've added your Short Circuit Protection Box to our Electrical category,
as well as to your builder page: mariost's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-short-circuit-protection-box">
<img src="/uploads/235712/homemade-short-circuit-protection-box.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-short-circuit-protection-box">Short Circuit Protection Box</a>
<span> by <a href="https://www.homemadetools.net/builder/mariost_2">mariost</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/electrical'>electrical</a> </div>
</div>
</div>
</div>
