Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Simple Dividing Head
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    Hemi,
    Yes, I did see your PM. Thank you!
    Dick
    Links to some of my plans:
  2. #12
    Alan Purdy's Avatar
    Sep 2016
    Bristol. United Kingdom
    Quote Originally Posted by bruce.desertrat View Post
    Interesting coincidence; I just picked up some 96 tooth gears at AS&S https://www.sciplus.com/3116-plastic-gear-58018-p with the thought of building something like this.
    This is a handy number because it gets you a lot of divisions out of one gear: 2, 3, 4, 6, 8,12,16,24,32,48 and I hate 1, 2,3,4,oops did I skip a tooth? So I have written a program to make a PDF with common divisions to glue into the gear. Right now it's a prototype, but I should be able to make it fully parametized: OD, ID, #teeth, desired divisions, etc, and stick it up on a website somewhere.
    Attachment 25545
    I suffer “aphasia”, stroke which means. I am unable to talk. Only “paste & copy” I am unable spelling.
    Indexing Wheel Hole Patterns - Evenly Spaced Layout Options
    Calculated and engineered 14, 36, 48 and 60-hole patterns allow for 20 obvious, symmetrical, evenly spaced layout combinations, as well as hundreds of asymmetrical layout combinations.
    14 Hole pattern makes 2-7-14 evenly spaced layout options
    24 hole pattern = 15° between holes
    36 Hole pattern makes 2-3-4-9-12-18-36 evenly spaced layout options
    48 Hole pattern makes 2-3-4-6-8-12-16-24-48 evenly spaced layout options
    60 Hole pattern makes 2-3-4-5-6-10-12-15-20-30-60 evenly spaced layout options
    Index – 20 different Even Combinations by degrees. (Even more options by skipping holes.)
    02 hole pattern = 180° between holes
    03 hole pattern = 120° between holes
    04 hole pattern = 90° between holes
    05 hole pattern = 72° between holes
    06 hole pattern = 60° between holes
    07 hole pattern = 51.4° between holes
    08 hole pattern = 45° between holes
    09 hole pattern = 40° between holes
    10 hole pattern = 36° between holes
    12 hole pattern = 30° between holes
    14 hole pattern = 25.7° between holes
    15 hole pattern = 24° between holes
    16 hole pattern = 22.5° between holes
    18 hole pattern = 20° between holes
    20 hole pattern = 18° between holes
    30 hole pattern = 12° between holes
    36 hole pattern = 10° between holes
    48 hole pattern = 7.5° between holes
    60 hole pattern = 6° between holes
    Can someone describe the difference in the final ground results between the 30 degree straight holder and the 12 degree compound one?
    The 30 degree would seem easier to make but there must be a good reason for the 12 degree compound one too
    Teach your children to remember, Lest We Forget.
  3. The Following User Says Thank You to Alan Purdy For This Useful Post:
    old_toolmaker (Sep 19, 2018)
  4. #13
    bruce.desertrat's Tools
    Quote Originally Posted by Hemi View Post
    Bruce,
    NICE find!!!!! I'm even looking into that one!!!!
    Dick,
    Please see my PM! Thanks my friend!
    Yeah AS&S is a really interesting place; I tend to find things I want/need pretty regularly, and thier prices are generally good. Even picked up a couple of these https://www.sciplus.com/80mm-roller-...earing-60117-p and yes they are truly huge. Some googling turned up that they are replacement bearings for a disk harrow disk , as in https://en.wikipedia.org/wiki/Disc_h..._-_1758939.jpg
    Just be aware they are definitely surplus, and things come and things go. So I've often picked up things just on spec.
  5. The Following User Says Thank You to bruce.desertrat For This Useful Post:
    Hemi (Sep 19, 2018)
  6. #14
    Thanks old_toolmaker! We've added your Dividing Head to our Lathe Accessories category,
    as well as to your builder page: old_toolmaker's Homemade Tools. Your receipt:
  7. The Following User Says Thank You to DIYer For This Useful Post:
    old_toolmaker (Oct 12, 2018)
  8. #15
    Dec 2017
    Cape Coral, FL
    Alan Purdy
    Thank you for your response!! It is all good information.
    Dick
