Thread: Slide hammer bearing puller adapter
    I have a little 4 lb slapjack for pulling dents but I needed to remove an axle bearing from a Masda pickup rear end.
    My solution was to use my very old internal bearing puller and the slapjack the only thing was the hammer has a 1/2 13 thread while the puller uses a 5/8 1. I removed the push shaft from the puller then welded a pair of 1/2 13 nuts to a 5/8 11 bolt
    After welding 2 nuts together I ran a tap through them to make sure of no conflicting threads
    then welded the nuts to the bolt I ground it just enough to remove sharp edges
    Race removed
    rossbotics (Jul 15, 2018), Seedtick (Jul 16, 2018), that_other_guy (Feb 2, 2019), Toolmaker51 (Jul 17, 2018)
    Thanks Frank S! We've added your Slide Hammer Bearing Puller Adaptor to our Automotive category,
