Slide hammer power increasing trick - video
That is a good trick, BUT after you remove the hub like that, make sure you replace the bearings or you will be back there again.
Quote:
Originally Posted by
hemmjo
Agreed. But usually the main reason for removing the hub is the bearings, but instead of using a slapjack hammer a puller with a center spindle bolt works better and not nearly so destructive on your body. Sometimes slid hammers are your only option I use mine quite frequently never tried wrapping a towel around it though to increase my force.
