Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Small beltsander/lathe attachment for rotary tool.
    Jyväskylä Finland
    Tuomas's Tools
    Just find out that someone has used my Youtube account and deleted this video. Have been trying to recover it, but seems that its gone. S#@!
  2. #12
    Jyväskylä Finland
    Tuomas's Tools
    Re-made video. Original one got deleted accidentally.
    New video contains some improvements and closer look to the build itself.
    "Plans with the main measures" measures are in millimeters. One inch is 25.4 millimeters.
    Attachment 14783Attachment 14784Attachment 14785
  3. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Nov 2, 2016)
  4. #13
    Banned
    Jul 2016
    Nice metal work there.
    I'd like to see the interface between the Dremel and the abrasive belt. What did you use/make?
  5. #14
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by extropic View Post
    I used that dremels rubbery sanding drum holder. It has worked nicely. Simple solution. ��
  6. #15
    Jyväskylä Finland
    Tuomas's Tools
    I was building another angle grinder attachment yesterday...
    Then i suddenly just figured out, how to make good diy pulley for dremel belt sander, and how to adjust belt tracking easily.
    Took some time, but finally i got it.
    Small beltsander/lathe  attachment for rotary tool.-fb_img_1534997571103.jpg
    So.. i tought i remake this build.
    Modified original build to use 520 or 533 x 30mm belts.
    Also cut it smaller and lighter.
    Works nicely.
    Test video can be seen from this link.
    https://www.instagram.com/p/BmyuWU0l...=185z7c7f2kpf3
  7. The Following 5 Users Say Thank You to Tuomas For This Useful Post:
    Frank S (Aug 23, 2018), high-side (Aug 25, 2018), Jon (Aug 22, 2018), PJs (Aug 23, 2018), Seedtick (Aug 23, 2018)
  8. #16
    Jyväskylä Finland
    Tuomas's Tools
    Here is about making the pulley. Real Diy solution, but works nicely. Also its light weighted. I think weight is very important with tools in this size.
  9. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
  10. #17
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Rubber stopper...Excellent application and the housing looks great and rigid! Thanks Tuomas for posting this upgrade!
    PJ
    Mark Twain
  11. #18
    Jyväskylä Finland
    Tuomas's Tools
    PJ
    Thanks PJs
    Yeah.. now i wonder why i didn't think it earlier.
    That rubber plug is inteted to protect threads in sandplasting.
    Its very elastic. I have used them for noise / fibration dampening too, under table / chair legs. Specially good in sauna or bathroom when it protects wood from the moisture too.
    Those are sold in 50 pcs packs here, so its good to have use for surplus too.
  12. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Aug 27, 2018)
  13. #19
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Thanks PJs
    On the late show here, but yes they are great for lots of uses and keep some around. They can be used for removing rust on chrome with a little water also and years ago I built a prototype sodium vapor lamp using them with wax seal for the tube evacuation. Didn't last long as the silver braze melted and the electrodes fell off...but the stoppers held up.
    Thanks Tuomas!
    Mark Twain
  14. #20
    mlochala's Avatar
    Nov 2012
    mlochala's Tools
    Very nice! I've been thinking of doing a small lathe like that myself. Great work!
    Download plans for lathes.
