Results 1 to 4 of 4
Thread: Small Pallet Lifter -- For Scaffold Crane
    Supporting Member bimmer1980's Avatar
    Jan 2018
    bimmer1980's Tools
    I thought I would do a detailed post about the construction of the pallet lifter that I use with the scaffold crane.
    http://www.homemadetools.net/forum/s...-lifting-65547
    I needed a small pallet lifter with about 100lbs or less capacity. I looked around at my material stock, worked up a basic design and then did some cursory number crunching.
    I came up with the following....
    Here is the steel bar and tube cut out.
    Then I started welding things together.
  2. The Following 2 Users Say Thank You to bimmer1980 For This Useful Post:
    jeanalvitre (Jan 7, 2018), Seedtick (Jan 6, 2018)
    Jan 2018
    bimmer1980's Tools
    I continued with the welding....
    I was also working on the rest of the crane, but I'll post those details in a separate thread.
    It was then ready to give it a test.....
  4. The Following User Says Thank You to bimmer1980 For This Useful Post:
    Jan 2018
    bimmer1980's Tools
    Once all the welding was complete, it was time to test it.
    After I used it for a period of time, I finally had a chance to take it inside the shop and clean it up for paint.
    I ended up painting it yellow with a few of the parts a grey.
    Then I continued to use it for the rest of my bricking project.
    Notice that the wheels are easy to take on and off. They are simply 5/8" bolts welded into an angle iron that slides into the pallet lifter tube. The wheels are from Harbor Freight.
  6. The Following 5 Users Say Thank You to bimmer1980 For This Useful Post:
    Altair (Jan 20, 2019), bukwessul (Jan 6, 2018), jeanalvitre (Jan 7, 2018), KustomsbyKent (Jan 6, 2018), Toolmaker51 (Jan 6, 2018)
    Thanks bimmer1980! We've added your Scaffold Crane Pallet Lifter to our Jacks and Lifts category,
    as well as to your builder page: bimmer1980's Homemade Tools. Your receipt:
  8. The Following 2 Users Say Thank You to DIYer For This Useful Post:
    bimmer1980 (Jan 6, 2018), jeanalvitre (Jan 7, 2018)
