Thread: Small Rotary Mill/Drill Fixture
    May 2012
    Byron, Michigan
    astroracer's Tools
    I built this little guy back in the mid-nineties to machine model car wheel centers. It simply clamped up in the cross-slide vise in the drill press and I would rotate it by hand to drill lug nut holes and make spokes in the wheel.
    As you can see it has a bit of a patina problem. Taking it apart you can see it is pretty simple. A small 3" chuck (Sherline I believe) a 3/4" dia. spindle threaded for 3/4-16 on one end and a turned block with a bronze bushing pressed into it.
    This shows a wheel center I made. It is kind of rough in the lug nut areas and is a reject piece. I made this table to solve the roughness issue. Never had a problem holding the pieces with this.
    This was used in the drill press and, now that I have the FrankenMill, I decided to fix it up a bit and do some of the stuff that I couldn't when I didn't have the tools. The first thing I did was mill off a couple of flat spots so it will clamp square and sturdy into the mill vise.
    Continued in next post
  2. The Following 8 Users Say Thank You to astroracer For This Useful Post:
    Alan Purdy (Aug 3, 2019), Danielt43 (Jun 11, 2016), davewhit (Sep 5, 2018), emu roo (Nov 13, 2025), j.bickley (Nov 25, 2017), jjr2001 (Nov 5, 2016), kbalch (Mar 6, 2016), PJs (Mar 9, 2016)
    May 2012
    Byron, Michigan
    astroracer's Tools
    The second thing I want to do is replace this clamp screw with a ball set screw for automatic detents.
    But first I need to make an adapter spindle so I can fit this 3" chuck to my H/V rotary table.
    That's another story.
    Mark
  4. The Following 7 Users Say Thank You to astroracer For This Useful Post:
    Alan Purdy (Aug 3, 2019), C-Bag (Mar 6, 2016), Danielt43 (Jun 11, 2016), emu roo (May 1, 2025), jjr2001 (Nov 5, 2016), Paul Jones (Mar 7, 2016), PJs (Mar 9, 2016)
    Thanks astroracer! We've added your Rotary Mill Drill Fixture to our Model Making category, as well as to your builder page: astroracer's Homemade Tools. Your receipt:
    Download plans for milling tools.
