Results 1 to 8 of 8
Thread: Snowblower cart
    Peat's Avatar
    Nov 2013
    Peat's Tools
    Snowblower cart
    Old snowblower plus old garden cart equals powercart.
  2. The Following 9 Users Say Thank You to Peat For This Useful Post:
    Andyt (Nov 30, 2018), baja (Nov 20, 2020), Jon (Nov 28, 2018), PJs (Dec 1, 2018), rossbotics (Nov 29, 2018), Seedtick (Nov 29, 2018), suther51 (Nov 30, 2018), thevillageinn (Dec 1, 2018), Toolmaker51 (Nov 30, 2018)
    KPL
    KPL is offline
    Nov 2018
    Isn't steering unstable?
    I have built something similar from a tiller, it is very difficult to steer; when I turn a little bit, it tends to turn further. It was actually usable only in reverse, then it stabilises itself. It has helped me a lot this way, anyway.
    Seems like pivot point is located much closer to powered axle in Your case, that might help. I was going to rebuild attachment to locate it under the engine, close to the wheel axle.
    https://photos.app.goo.gl/25XbwNKb7FACRteL7
    Peat's Avatar
    Nov 2013
    Peat's Tools
    Quote Originally Posted by KPL View Post
    Mine steers fine, more by accident than design though! Been hauling wood to stack....its a short haul and a wheel barrow would work just as well but this was a fun project.
    KPL
    KPL is offline
    Nov 2018
    Mine was built to carry seaweed visible in that linked photo. It's wet and heavy, and has to be carried quite far sometimes. The main problem is a loose sand I had to cross, where wheels tended to slip and dig in.
    It's quite many wheelbarrow loads that fit into that trailer, so it was really worth it.
    Thanks Peat! We've added your Snowblower Cart to our Farm and Garden category,
    as well as to your builder page: Peat's Homemade Tools. Your receipt:
    I really don't know one thing about designing trailers. But I have a trailer ball front and back of my truck. Whatever maneuvering I accomplish hooked up conventionally, is a mere fraction connected in front. All in mechanics; distance of swivel from steering, like a long flatbed truck trying what 5th wheel tractors do.
    Peat's arrangement benefits that link swivels on motor chassis [and close to drive axle], where the connection on KPL's is on the trailer frame, greatly increasing the ratio attained. Ratio also applies in distance from link to axle of trailer itself.
  8. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Dec 1, 2018)
  9. #7
    Feb 2018
    I always wondered why no one ever marketed a snowblower/tiller combination. Of course I guess the early Gravely's and some other early walk-behind tractors would do a lot of different things also.
  10. #8
    Apr 2017
    Peat & KPL
    both designs are pretty cool, I've been looking to convert an old snowblower into a way to haul my pump and motor and hold the hose, in one.
    the steering difference is probable due to the size of the tires on the wagons???? just a guess based on the little physics I know.
