Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Socket Wrench Thumb Wheel for close quarters use and speed use
    Jon, I have made some like the second one in your list. Each size having 2 examples, one with the nut holder fixed and the other with a round and knurled outer surface. The first holds the nut stationary and expects that the bolt can be turned into the nut. The second is free to rotate and can be turned by a thumb, this is useful when the bolt/stud is fixed and you need to wind the nut on.
    I have these in 8, 10, 13 and 17 mm which are my most used sizes.
  2. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    jjr2001 (Feb 10, 2019), Paul Jones (Feb 10, 2019)
  3. #12
    jjr2001's Tools
    Hmmmm, I think the last one that Jon posted looks like a "universal" type that could be used on
    several sizes of bolts or nuts. Also has an advantage that the others don't. It could run a nut
    up a long bolt a long way since it is open on both sides.
    Cheers, JR
  4. #13
    Cheers, JR
    Yes but wouldn't your arm get awfully twisted?
  5. The Following User Says Thank You to tonyfoale For This Useful Post:
    jjr2001 (Feb 16, 2019)
  6. #14
    Through hole allows running fasteners on threaded members of unlimited length...
    Yes again, but think how fast he could then UNDO one...
  7. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  8. #15
    Interesting. Each one of these has at least one cool little feature. I like how the extendible finger tool patent includes a drawing of all of the extensions:
    Extendible Finger Wrench Extensions
  9. The Following User Says Thank You to Jon For This Useful Post:
  10. #16
    jjr2001's Tools
    Very cool, thanks for posting Jon
    Cheers, JR
  11. #17
    These double as marital aides. When you're in the doghouse, still have something to do in the shop.
  12. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    jjr2001 (Feb 10, 2019), PJs (Feb 11, 2019)
  13. #18
    Supporting Member toma's Avatar
    Serbia
    toma's Tools
    If someone does not know how to break his own finger...!
  14. The Following User Says Thank You to toma For This Useful Post:
    jjr2001 (Feb 14, 2019)
  15. #19
    Cheers, JR
    Yes but it would be very slow if you had a long thread. I think that a finger and thumb are required always when in use, limiting the thread advance per twist of the wrist. The two sides slide apart or together and so need a force to hold each side on to the nut/bolt. The advantage is that this device is suitable for various size hex or square heads. The disadvantage is that to avoid twisting your arm off you could only rotate it up to around 90 deg. which would be OK for square heads and include 60 deg for normal hex bolts/nuts. It might allow for long threads but it would not be fast because you would be restricted to one, or two at the most, flats at a time. You would need to proceed as; open, align with flats, close on flats, twist, open again, reverse twist and repeat ...................................
    In my humble opinion it is a poor solution and would end up in the "tools I never use box" very quickly.
    You can now get sockets with through holes, or a regular hand tapping holder (or similar home made device for hex heads) would run nuts up long threads much faster.
  16. The Following User Says Thank You to tonyfoale For This Useful Post:
  17. #20
    Thanks jjr2001! We've added your Socket Thumb Wheel to our Fastening category,
  18. The Following User Says Thank You to DIYer For This Useful Post:
