Thread: SOLDERING IRON USING GLOW PLUG
    Feb 2019
    mariost's Tools
    A useful tool we can use in a place where there isn' t electric current. For example in the car , at the country etc. It needs a 12 volt battery. It works with about 20 A current , so I 've put a 30 A relay that gets the order from a small switch. The power of the glow plug is about 230 to 250 W so we must not operate continuously more than 8-10 sec to avoid overheating. I ' ve also connected a piece of copper (or bronze) to the end of the plug to have better adhesion with the soldering wire.
    YOU CAN WATCH THE VIDEO OF THE CONSTRUCTION HERE.
    Attached Thumbnails Attached Thumbnails SOLDERING IRON USING GLOW PLUG-2.jpg   SOLDERING IRON USING GLOW PLUG-3.jpg   SOLDERING IRON USING GLOW PLUG-4.jpg   SOLDERING IRON USING GLOW PLUG-5.jpg   SOLDERING IRON USING GLOW PLUG-6.jpg
    SOLDERING IRON USING GLOW PLUG-8.jpg   SOLDERING IRON USING GLOW PLUG-9.jpg   SOLDERING IRON USING GLOW PLUG-2-4-2019-10-39-34-.jpg
    Last edited by mariost; Apr 2, 2019 at 03:35 AM. Reason: A mistake in the shematic (not the construction that iw ok)
  2. The Following 3 Users Say Thank You to mariost For This Useful Post:
    Scotsman Hosie (Apr 11, 2019), sossol (Apr 2, 2019), tonyfoale (Apr 3, 2019)
    Feb 2019
    mariost's Tools
    A mistake in the shematic. The + of the battery goes direct to the resistor before the switch. The connection in the shematic is before the switch and not after it. In fact the construction is ok. I made this mistake later in the shematic.
    I like it, great idea. The temperature could get to be excessive for soldering but that could easily be controlled by the supply voltage to give a longer duty cycle.
    I have several glow plugs in a scrap box, I know what to use one for now. Thanks.
