Results 1 to 10 of 11
Thread: Solid fuel forge
    Nov 2015
    Italy
    rendoman's Tools
    Solid fuel forge
    Hi all!
    I'm trying to make a solid fuel side forge, useful even as a barbecue
    I found good metal scrap, a round part thick 1\2", good as base. I did air intake from square tube. A broken hairdryer, resistor is gone, will be the air source, I hope it will survive
    I built lateral bulkheads from 0,8mm steel, I folded with hammer the edges, because they are really sharp!
    I'm thinking about making them detechable, in order to clean and to use as barbecue
    Saluti
    Stefano
    Solid fuel forge-dsc01138_1600x1200.jpg Solid fuel forge-dsc01140_1600x1200.jpg
    Solid fuel forge-dsc01141_1600x1200.jpg Solid fuel forge-dsc01142_1600x1200.jpg
    Solid fuel forge-dsc01143_1600x1200.jpg Solid fuel forge-dsc01145_1600x1200.jpg
  2. #2
    Nov 2015
    Italy
    rendoman's Tools
    Next part: choose a good solution for fixing air intake + hairdryer
  3. #3
    Nov 2015
    Italy
    rendoman's Tools
    Small update
    It's ready the conversion from forge to barbecue
    316 marine steel, I buyed some months ago as faraday cage for my plasma tweeter, never used for this purpose.
    15cm high, good size to be practical inside forge and very easy to clean with soap or a pressure washer
    Solid fuel forge-dsc01158_1600x1200.jpg Solid fuel forge-dsc01159_1600x1200.jpg
  4. #4
    Nov 2015
    Italy
    rendoman's Tools
    I found this fan, imho too much powerful as forge source, I'm thinking about possibility to use with an air valve
    Solid fuel forge-dsc01162_1600x1200.jpg Solid fuel forge-dsc01163_1600x1200.jpg Solid fuel forge-dsc01164_1600x1200.jpg
  5. #5
    Supporting Member jotasierra's Avatar
    Sep 2015
    país Argentina, provincia de San Juan
    jotasierra's Tools
    Hola Rendoman, lindo proyecto y en realidad se ve muy poderoso ese forzador pero creo que si se deja libre una parte de la salida de aire podría enviar menos caudal a la fragua, suerte y hasta pronto.
  6. #6
    Nov 2015
    Italy
    rendoman's Tools
    Thanks Jotasierra!
    I added the air intake, I hope in a good position for cooling engine and not damage plastic body of fan
    Have to finish welding and to make the slide valve, hope in a couple of day to finish!
    Solid fuel forge-dsc01165_1600x1200.jpg Solid fuel forge-dsc01166_1600x1200.jpg Solid fuel forge-dsc01167_1600x1200.jpg
  7. #7
    Nov 2015
    Italy
    rendoman's Tools
    Finished!
    I added a front cover and opened a lateral window. I'm not sure of the height of the round cover, maybe I will cut after some attempt.
    Slide valve on air intake runs good, currently I don't know how much air forge needs, but I can modify the flux from 0 to max.
    Saluti
    Stefano
    Ps: I will add a ready to use switch on off to drive fan
    Solid fuel forge-dsc01169_1600x1200.jpg Solid fuel forge-dsc01170_1600x1200.jpg
    Solid fuel forge-dsc01171_1600x1200.jpg Solid fuel forge-dsc01172_900x1200.jpg
  8. The Following 2 Users Say Thank You to rendoman For This Useful Post:
    Jon (Nov 10, 2019), Toolmaker51 (Sep 14, 2016)
  9. #8
    Sep 2015
    jotasierra's Tools
    Felicitaciones rendoman, a darle trabajo a esa fragua, y festejar con otra torta de frutillas
  10. #9
    Thanks rendoman! We've added your Forge to our Forging and Casting category,
    as well as to your builder page: rendoman's Homemade Tools. Your receipt:
  11. The Following User Says Thank You to DIYer For This Useful Post:
    rendoman (Sep 14, 2016)
  12. #10
    Quote Originally Posted by rendoman View Post
ID:	13586 Made, by the way, a couple hundred miles from me.
    After a tough afternoon at fire in that forge...
    Hungry tired, needing to relax. Already in Northern Italy too [just in case this flew under your radar] I disconnected link for page space. You can unwrap it like a gift.
    http://www.homemadetools.net/forum/a...ent-park-51273
    Saludo Rendoman, you've been busy!
