Results 1 to 5 of 5
Thread: solution to losing small screws
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    I was asked by a friend if I could have a look at his vapour cigarette. After looking at it, the screws were very small stainless steel T6 torxs. I knew that if I dropped one I wouldn’t have a replacement and guaranteed if I put them in a pot, I would knock it over. So the solution was sat on the bench in front of me in the form of parcel tape. So I tested my idea with some screws that I had plenty of to make sure it would work. The simple solution was to put a piece of parcel tape in the bottom of a plastic container and the screws would stick to the tape so even if the pot was knocked over it would retain the contents.
    The photos below show the pot.
    solution to losing small screws-a19f9992-fb67-498a-8fe6-816b417cdb3e.jpegThe tape is folded back on itself so the tape sticks to the pot
    solution to losing small screws-0ec747fc-97e1-4451-b8ea-5bfd4a3ff056.jpeg Test screws.
    solution to losing small screws-a77590ac-f194-4231-8115-8dd17ff0e59e.jpegTesting the pot upside down.
    No screws lost and the vapour cigarette repaired.
    Hope this is post is helpful.
    The Home Engineer.
  2. The Following 4 Users Say Thank You to thehomeengineer For This Useful Post:
    EnginePaul (Dec 11, 2022), Jon (Dec 7, 2022), Philip Davies (Dec 3, 2022), uv8452 (Dec 5, 2022)
    Before I work with parts that tiny I lay a microfiber cloth...
    https://www.amazon.com/AmazonBasics-...40&sr=8-2&th=1
    on the work surface. They're "lossy" enough that any small object dropped on them loses all its energy into the cloth and remains exactly where it landed. The bright colors make it easy to locate tiny findings.
    You'll "sproing" fewer tweezer-held objects if you use plastic-tipped tweezers. They can be bought...
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    or you can make your own by dipping ordinary tweezers into liquid electrical tape...
    https://www.amazon.com/Star-brite-Li...s%2C155&sr=8-3
  4. The Following 5 Users Say Thank You to mklotz For This Useful Post:
    baja (Dec 6, 2022), EnginePaul (Dec 11, 2022), rlm98253 (Dec 5, 2022), thehomeengineer (Dec 3, 2022), Toolmaker51 (Dec 6, 2022)
    Thanks thehomeengineer! We've added your Small Screw Holder to our Storage and Organization category,
    Supporting Member imohtep56's Avatar
    Sep 2016
    I've always used my old pill bottles for that purpose. Never lost any small screws. Just forgot where I left the bottle...
    Quote Originally Posted by imohtep56 View Post
    Small parts cups with no corners are easily made from the bottoms of soda cans. See...
    Small parts cups
    A magnet glued to the bottom of the cup will trap ferrous findings, or...
    Wipe the bottom of the cup with a Posit glue stick, e.g....
    https://www.amazon.com/Scotch-Restic...s%2C199&sr=8-5
    and tiny findings can't escape, even if they're not ferrous.
    BTW, if your screen name refers to Pharoh Djoser's architect, later deified, you're misspelling it. It's Imhotep, not "Imohtep".
