Could probably roll the crank over until the intake valve is open then blast compressed air in the intake valve to blow chips out while tapping. That might be the best bet. I still wouldn't trust it 100% though.
Exactly, then vacuum a little with a small hose and you're off to the races with a ten buck fix even if it only lasts a month and could go quite a while longer.
