Results 1 to 4 of 4
Thread: Spark Plug Tube Removal Trick
    Sep 2018
    nova_robotics's Tools
    Here's a little trick to remove leaky spark plug tubes. Just jam an NPT tap in the old tube and pry it out with a flat head screwdriver. This is an alternative to the OEM tool (that expands the plastic and doesn't really work).
  2. The Following 9 Users Say Thank You to nova_robotics For This Useful Post:
    Altair (Oct 16, 2021), asterix (Oct 16, 2021), emu roo (Apr 11, 2026), luvmygto (Oct 19, 2021), mwmkravchenko (Oct 15, 2021), Sleykin (Oct 24, 2021), sossol (Oct 16, 2021), TheElderBrother (Apr 12, 2026), WorkerB (Oct 16, 2021)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    I could have used this when pulling the tubes out of my R53 mini Cooper S head. They're steel, but I think this would work on them just as well. I ended up using pliers and a block of wood to pry against. It worked, but risked damaging the head.
    Neil
  4. The Following User Says Thank You to sossol For This Useful Post:
    I have used a similar trick to pull the injector sleeve tubes out of caterpillar engines
    TheElderBrother's Avatar
    Sep 2019
    The Land of Cotton
    I will probably never own a Porsche, but it's still cool to know these tricks.
