Results 1 to 10 of 10
Thread: speedy drill-mill depth stop
    Sep 2018
    Groningen, NL
    Carnel's Tools
    Speedy drill-mill depth stop
    I replaced my full threaded depth stop bar with an unthreaded one. An alu ring with set screw completes it.
    speedy drill-mill depth stop-depthstop1.jpgspeedy drill-mill depth stop-depthstop2.jpg
  2. The Following 10 Users Say Thank You to Carnel For This Useful Post:
    57_210 (Mar 20, 2021), chy_farm (Jul 30, 2020), emu roo (Feb 20, 2025), Floradawg (Oct 10, 2020), Jon (Oct 9, 2020), Ken Koch (Oct 5, 2018), olderdan (Oct 4, 2018), PJs (Oct 14, 2018), Seedtick (Oct 4, 2018), Toolmaker51 (Oct 7, 2018)
    olderdan's Tools
    Hi Carnel,
    I have tried a few methods but this is the best style of quill stop I have used, I have bonded a base disc to the rough cast surface to get a more accurate distance from a spacer. I never thought to post it but I am glad you did. Great minds and all that.
    Regards
    Olderdan
  4. The Following 4 Users Say Thank You to olderdan For This Useful Post:
    chy_farm (Jul 30, 2020), emu roo (Oct 2, 2025), PJs (Oct 14, 2018), Toolmaker51 (Oct 7, 2018)
    Sep 2018
    Groningen, NL
    Carnel's Tools
    Thanks, Olderdan. your addition of a base disk is great. I will implement that idea.
    Regards, Carnel
  6. The Following User Says Thank You to Carnel For This Useful Post:
    Apr 2016
    put a key way in your collar and add the key to it so the screw presses on the key,, witch presses on the shaft to hold it all in the correct posisition you want..that way you dont get any boogers on the shaft,witch will eventuly kill the shaft as well as make it hard for fine work as the boogers will throw it off. I would use a 3/8 wide key or however wide the flat is. you can make the key a tad short and add a small set screw at each end of the collar to hold the key in place at all times so it dont slide out when not tightened to shaft. using drills is a good quick way to get the size you want. keep up the great work!!!
  8. The Following 2 Users Say Thank You to marksbug For This Useful Post:
    emu roo (Oct 2, 2025), tooly (Oct 9, 2020)
    Sep 2018
    Groningen, NL
    Carnel's Tools
    That's right, marksbug! I thought to use another set screw with a flat tip in stead of a hollow one. But a key will probably be a better choice.
    Thanks and regards,
    Carnel
  10. The Following User Says Thank You to Carnel For This Useful Post:
  11. #6
    olderdan's Tools
    A key would be the Pukka way but as I am lazy I have simply set a brass pellet to the flattened end of the set screw, my collar is steel so a reduced thread depth is no big deal.
  12. The Following 2 Users Say Thank You to olderdan For This Useful Post:
  13. #7
    Apr 2016
    yup a brass puck will do, like the lathes that have a brass rod on end of screw for jib adjustment. you could even make it a cam lock with a brass puck or key.but a knob works wonders.keep up the great work it keeps us all thinking.and always remember even if you dont need something dosent mean that concept cant be adapted or modified to work on something else thats got you pulling hair.sometimes it can get you thinking in a totaly different direction and... Boom!!! you got it!!! thats what I love about this site!!! More brains= less strains.
  14. #8
    Sep 2018
    Groningen, NL
    Carnel's Tools
    @ olderdan & marksbug: a lot of alternatives! Collective brains are creative. I will get a choice.
    Carnel
  15. The Following User Says Thank You to Carnel For This Useful Post:
    PJs (Oct 14, 2018)
  16. #9
    Thanks Carnel! We've added your Speedy Depth Stop to our Drilling and Drill Presses category,
    as well as to your builder page: Carnel's Homemade Tools. Your receipt:
  17. The Following User Says Thank You to DIYer For This Useful Post:
  18. #10
    Thanks olderdan! We've added your Depth Stop to our Drilling and Drill Presses category,
  19. The Following User Says Thank You to DIYer For This Useful Post:
