Thread: Spot Face cutter
Hybrid View
    Supporting Member Workshopshed's Avatar
    Mar 2013
    Suffolk, UK
    Workshopshed's Tools
    Spot Face cutter
    I was making a stripboard project for a magazine and wanted a quick and easy way to make the cuts in the tracks. So I made my own spot face cutter from an old drillbit and a bit of old branch from thee garden.
    Spot Face cutter-img_20200415_162528.jpg Spot Face cutter-img_20200415_172853.jpg
    https://www.workshopshed.com/2020/04/spot-face-cutter/
    Andy from Workshopshed
    "Making and repairing things in a shed at the bottom of the garden"
    workshopshed.com
  2. The Following 8 Users Say Thank You to Workshopshed For This Useful Post:
    emu roo (Apr 22, 2025), Jon (Apr 23, 2020), n9dug (Apr 27, 2020), Paul Jones (Apr 22, 2020), rgsparber (Apr 20, 2020), rlm98253 (Apr 20, 2020), Sleykin (May 13, 2020), Tule (Apr 21, 2020)
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    Vector makes an expensive tool for cutting these traces. Well, expensive compared to a standard drill bit. I have been using drill bits for this for years. I put a 1/8" bit in my drill press and set the down feed stop for the correct depth to remove the trace. That takes a few trials. From there, I just mark the places to break the traces with a marking pen and drill away. The hole in the board centers the drill bit very well and the 1/8" size bit cuts the trace with a wide enough break so that solder will not bridge it easily but it does not touch the neighboring traces. Works great.
    Paul A.
  4. The Following User Says Thank You to Paul Alciatore For This Useful Post:
    IAMSatisfied (Apr 27, 2020)
