Results 1 to 8 of 8
Thread: Strand jacking system - GIF
    May 2024
    nova_robotics (Jan 26, 2025), Ralphxyz (Jan 30, 2025)
    Sep 2018
    nova_robotics's Tools
    What on Earth is this? Did they just stack prefabricated floors from the bottom to build that building??? I've never heard of anything like this.
    Aug 2021
    Cape Town SA
    albertq's Tools
    What a strange building system. Clearly didn't take off as a viable method as I've never seen anyone build like this.
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Clearly a response to rising sea levels?
  6. The Following User Says Thank You to Philip Davies For This Useful Post:
    ductape (Jan 26, 2025)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    I had to look this one up. I found this:
    "A strand jack is a system similar to a jack, however in this case the load is not pushed up, but the jack pulls up a bundle of wires, which is called a strand."
    and this:
    "The Enerpac strand jack system provides precise synchronous control in a compact footprint. With lifting load capacities from 17 to 1,405 tons per jack, strand jacks are an ideal heavy lifting solution when a conventional crane is not practical or economical. Up to 60 strand jacks can be simultaneously controlled by a single operator from a central location which optimizes safety."
  8. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    Philip Davies (Jan 26, 2025)
    Sep 2020
    About 1976 a building in my hometown in Wisconsin was built like this. Vertical parts were fabricated then each floor was poured in the basement where basement became the form for the pour. Then the floor was jacked up to the upper level where it was locked in place. The building is still standing after almost 50 years. It's about 6 stories tall. I never came across this method again in 40+ years of work in facilities. It was faster than "normal" methods but there must be some limitation as it never took off in my experience.
  10. #7
    Dec 2022
    Midwest US
    ductape's Tools
    May be some type of seawall or levee, as Philip Davies suggested. It looks a heck of a lot more expensive than the usual wall of dirt.
  11. #8
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by ductape View Post
    Nova robotics thinks it is a prefab building, I agree. If you look at the "center" shapes, they look like stairwells with doors or perhaps elevator door spaces. Building on the ground is much easier than having to move materials up high...
