Results 1 to 9 of 9
Thread: Swing Up Threading Tool
    Apr 2015
    Kingsburg California
    Cruizer67's Tools
    Here is a swing up lathe threading tool that I built to make threading faster and more accurate
    the concept is to run threading tool to length and then without having to disengage threading mechanism from lathe just stop spindle and run in reverse. the threading tool disengages and swings up a bit to clear thread then when its clear of part stop and run spindle in correct direction adjust and move in thread and start over ... here are pictures and a video will be attached soon
  2. The Following 2 Users Say Thank You to Cruizer67 For This Useful Post:
    kbalch (Apr 27, 2015), Paul Jones (Apr 24, 2015)
    Cool build. A video of it in action would be great!
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Very nice build cruizer67.
    Pretty cool. Looking forward seeing the video!
    Al
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Bernard,
    Nice work. I could use this tool when machining metric pitch threads with my lathe. Cutting metric threads my lathe requires keeping the lead screw split nut fully engaged at the end of each cut and requiring reversing the lathe before starting the next cut (probably more typical of cutting metric threads with imperial lead screw lathes).
    Thanks you for the ideas, Paul
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Cruizer67! I've added your Swing Up Threading Tool to our Tapping and Threading category, as well as to your builder page: Cruizer67's Homemade Tools. Your receipt:
  8. #7
    Apr 2015
    Cruizer67's Tools
    I will get video shot and posted soon.
    Thanks for the feedback
  9. #8
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    I have the same problem as Paul with my lathe for metric and I like your simple solution. Time for some more tool making. Randy
  10. #9
    Apr 2015
    Cruizer67's Tools
    here is video of it in operation
