Thread: T-handle tap wrench guide pin
Hybrid View
    If you use a T-handle tap wrench in a lathe, mill, or drill press, it really should be fitted with a guide pin to keep it from stressing the tap laterally since that is a major cause of tap breakage. You can buy guided tap wrenches commercially but it's a simple job to make your own.
    Drive the handle out of the wrench and bore a bit of metal (I used brass) to fit over the head of the wrench. In the end of this chunk drill a hole to be a nice sliding fit on a short rod (I used 1/4" drill rod). Crossdrill the brass to accept the handle. Assemble and drive the handle back through to lock the brass onto the wrench. I leave the guide rod unrestrained but you can add various devices to restrain it if you wish; I don't find it necessary.
  2. The Following 10 Users Say Thank You to mklotz For This Useful Post:
    baja (Aug 1, 2019), CookieCrunch (Aug 1, 2019), emu roo (Mar 12, 2025), Home-PC (Mar 19, 2021), jjr2001 (Jan 8, 2018), Jon (Feb 26, 2016), kbalch (Feb 26, 2016), oldpastit (Aug 1, 2019), Paul Jones (Feb 26, 2016), PJs (Feb 29, 2016)
    Thanks mklotz! We've added your T Handle Tap Wrench Guide Pin to our Tapping and Threading category, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
    emu roo (Nov 7, 2025)
