Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Tail Stock Taper Turning Attachment
    Dec 2013
    Florida
    rossbotics's Tools
    Hi Doug
    The plans for this tool are being edited, should be done in about a week, they will be available soon
    Doug Ross
    Comments are always welcome
    Doug
  2. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    Paul Jones (Mar 2, 2018), PJs (Jun 30, 2018)
  3. #12
    ChrisB257's Avatar
    ChrisB257's Tools
    Very fine work as usual - nicely done. Thank you.
    Ain't technology great - until it goes wrong!
    The Old Man's Shop
  4. #13
    Ralphxyz's Tools
    Thanks!! Has to be the best instruction for scribing an index dial and adding the numbers I have seen!!
    I was worried about hold the tool level, I think your comments describe adequately what to do to "lock it in".
    Ralph
  5. #14
    Jan 2018
    ddickey's Tools
    I just finished mine. A really good project. Turned out nice. I don't have any straight knurls so used a fine diamond but sort of botched it. Not sure if it was the gummy aluminum or operator error. Also my knurler is for 2" max diameter so had to set it up off center quite a bit, I'm sure that didn't help. Also I had no way to mark out the thou and half thou lines so this is how it will be.
  6. The Following 8 Users Say Thank You to ddickey For This Useful Post:
    Jon (Aug 10, 2018), olderdan (Aug 10, 2018), Paul Jones (Aug 10, 2018), PJs (Aug 12, 2018), rossbotics (Aug 10, 2018), Seedtick (Aug 10, 2018), Toolmaker51 (Aug 10, 2018), zarembak (Aug 10, 2018)
  7. #15
    Quote Originally Posted by ddickey View Post
    You may have alternate methods to mark .001 and intermediate halves. It depends on the diameter relation to dividing sensible degrees. It might only take a height gauge and scriber.
    Lots of folks print a degree wheel and chuck the part in their lathe.
    You could print a linear scale and vernier, or attach a small travel indicator, or add plunger and detents but that might be crowded. Another comes to mind using a convenient pitched screw or micrometer head...Here it would 'monitor' movement separate from the actual screw doing the offset.
    A differential screw wouldn't need much travel and be any rotational increments desired.
    A diamond knurl can do single angled knurls, just remove one wheel. There is much ado about which knurl -straight or diamond- for certain uses. That applies more to commercial products, and deeper product pockets. A better guide is to apply them per task at hand. Diamonds do NOT have to be fully formed, just sort of deep scribed lines and work nicely.
    Last edited by Toolmaker51; Aug 11, 2018 at 02:50 AM. Reason: Thinking more at @ a quarter to four...than with a plate at eight.
  8. The Following 3 Users Say Thank You to Toolmaker51 For This Useful Post:
    Home-PC (Sep 14, 2020), Paul Jones (Aug 10, 2018), PJs (Aug 12, 2018)
  9. #16
    Supporting Member ncollar's Avatar
    Oct 2012
    Doug
    Beautiful job but we have come to expect that from the resident tool and die man.
    Very nice work
    Nelson
  10. #17
    Dec 2013
    Florida
    rossbotics's Tools
    You did a beautiful job ddickey !
    I made a graduated scale drawing that was to be printed on decal paper for people that had no way of indexing those graduations, as long as you held the diameter of the hand wheel as stated on the drawing otherwise you can measure the diameter of your hand wheel and do a cad drawing yourself that will match the circumference of your wheel, that's how I made the original.
    Other than that you did a beautiful job and great work !
    Jon the Admin. will let you have a set of my plans of your choice free for posting your completed tool !
    Great Job ddickey !
    And thank you for posting your completed project
    Doug
    Doug
  11. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    Home-PC (Sep 14, 2020), PJs (Aug 12, 2018)
  12. #18
    Free plans sent out to ddickey
