You use a pass through ratchet that also holds the spline. cumbersome to have to use the powered torque tool to run up the bolts or to have a dozen of those on a jobsite, and as you said the first bolt torqued if the rest are not already tight that one is impossible to retorque. Even a simple spud wrench and a box spline wrench is preferable to torquing a bolt next to a gang of loose bolts
