Results 1 to 10 of 13
Thread: Test if your gas has two cycle oil added or not.
    mr_modify1's Avatar
    Nov 2021
    mr_modify1's Tools
    This is the most positive way I have found yet.
  2. The Following 13 Users Say Thank You to mr_modify1 For This Useful Post:
    albertq (Dec 29, 2023), durrelltn (Oct 24, 2022), emu roo (Nov 11, 2024), EnginePaul (Oct 21, 2022), gjwill22 (Oct 17, 2022), hardlylook (Jun 1, 2023), johncg (Oct 18, 2022), Jon (Oct 20, 2022), nova_robotics (Oct 17, 2022), rlm98253 (Oct 23, 2022), Sleykin (Oct 23, 2022), thevillageinn (Oct 17, 2022), verticalmurph (Jun 2, 2023)
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    What are the strips originally for? He said something about a hot tub and a pool. I watched and listened 3 times and couldn't make it out.
  4. The Following User Says Thank You to katy For This Useful Post:
    emu roo (Nov 27, 2025)
    Supporting Member bob_3000's Avatar
    Aug 2020
    Why would you need a test strip? Just look at the gas, no oil..clear...with oil, blue tint.
  6. The Following User Says Thank You to bob_3000 For This Useful Post:
    Sep 2018
    nova_robotics's Tools
    That's a great tip. Thanks!
  8. The Following User Says Thank You to nova_robotics For This Useful Post:
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    https://www.google.com/search?q=pool...UTF-8&hl=en-us
    He described what they are…but if you aren’t familiar with them they may not make a lot of sense. The strips are a quick way to check pool and spa water for basic chemical levels - chlorine, ph, some acid, and some other things.
    Although it would have been nice to know what substance the indicator which changed was for, not all test strips have all the same substances represented. He’s offering a tip and a method to see whether you get similar results before relying on it - get some strips and see what happens between mixed and non-mixed gas.
  10. The Following 2 Users Say Thank You to thevillageinn For This Useful Post:
    emu roo (Nov 27, 2025), Sleykin (Oct 23, 2022)
  11. #6
    Thanks mr_modify1! We've added your Fuel Mixture Test Method to our Miscellaneous category,
    as well as to your builder page: mr_modify1's Homemade Tools. Your receipt:
  12. The Following User Says Thank You to DIYer For This Useful Post:
  13. #7
    May 2021
    Most mixing oil manufacturers do tint their oil, but some do not. In order to avoid even needing this test (which I like) I try to buy a tinted mixing oil, and I keep it in a container marked as such. You can even buy laminated tags for fuel cans that are multi lingual and can be attached and removed if the container is used for different liquids.
  14. #8
    hemmjo's Tools
    I did not even watch the video. WHY would you even bother to test that tiny amount of fuel to see if it has oil? If it has been so long you cannot remember which container has oil, the fuel is too old to be good for your small engine anyway. Mix it with 5 gallons of fresh gas and use it in your car or truck!! Then mix a fresh batch for your saw or whatever.
  15. The Following 4 Users Say Thank You to hemmjo For This Useful Post:
    bob_3000 (Sep 8, 2023), emu roo (Nov 27, 2025), Gadgeteer (Oct 24, 2022), Toolmaker51 (Jun 1, 2023)
  16. #9
    mr_modify1's Avatar
    Nov 2021
    mr_modify1's Tools
    The strips are swimming pool or hot tube test strips to test for chlorine content etc.
  17. The Following User Says Thank You to mr_modify1 For This Useful Post:
  18. #10
    mr_modify1's Avatar
    Nov 2021
    mr_modify1's Tools
    Strips were use fir a Hot tub.
  19. The Following User Says Thank You to mr_modify1 For This Useful Post:
