Quote Originally Posted by DIGGERJR View Post
I have seen where a vise was mounted to a steel post using pipe chain. I would like to make this so it is portable. I work in a new built body shop, at the garage doors there is 8" pipe to protect anyone from hitting the the walls. It would be a good place to mount.
IMO, the easiest and most stable platform would be made by mounting the vice to a suitable piece of angle steel (10" x 10"? on a side 1/4" thick) mount the vice to it and then have 2.... 1/2" or 5/8" U-bolts made by the local spring shop and then attach the angle to the pole with those. IMO, (I believe) the chain vice is going to have to much "give" to be of any use. If you want to try it though mount the angle and vice to the base of the chain vice and attach the chain vice to the pole.
