Results 1 to 8 of 8
Thread: Thicknessing attachment.
    hammer's Avatar
    Sep 2015
    hammer's Tools
    I build model ships, for which I need large amounts of thin strips of wood. The problems making strips down to 1.5mm are numerous. A circular saw tends to snap them on the back of the blade, they also disappear down between the blade & packing. A band saw will tend to take to the soft grain, giving inconsistent thickness. A normal wood working thicknesser no good at all. Thicknessing attachment.-img_0001.jpgThicknessing attachment.-img_0002.jpgThicknessing attachment.-img_0003.jpg Using a belt sander upside down an adjustable roller is fitted near the end. The thicker strips cut on a saw is pushed through against the rotation of the drum. the results can be seen. Although the roller looks out of parallel in the photo it is not.
  2. The Following 5 Users Say Thank You to hammer For This Useful Post:
    jere (Sep 21, 2015), johnsmachines (Aug 6, 2024), Jon (Sep 14, 2015), kbalch (Sep 14, 2015), PJs (Sep 16, 2015)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I like your design and will be useful for other types of modeling work and miniature furniture building. Thanks for posting this.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks hammer! I've added your Thicknessing Attachment to our Thickness Sanders category, as well as to your builder page: hammer's Homemade Tools. Your receipt:
    Great Idea, Hammer! Got a project coming up for my grandson that this would be really useful. The nice feature is that you can make any thickness and keep it consistent over a run. Did you use roller bearings inside the copper or just bushings? Thanks for the useful post! ~PJ
    Pretty neat and simple mod. A second bracket to support the other end of the roller is probably unecessary, but it would be a good addition IHMO.
    Al
    Supporting Member jere's Avatar
    Feb 2015
    jere's Tools
    great solution! that could clean up old boards that have hidden nails without risking pricey power planer blades.
    I have been reading about bandsaw a lot lately, and the awkward cuts are a result of the way the saw is set up. low tension of the blade seems to be a very likely culprit. bearings guides and tires could play roles if you want to open that can of worms
  8. The Following User Says Thank You to jere For This Useful Post:
    Paul Jones (Sep 22, 2015)
    Cool idea. As one who dabbled in modelling years ago, I'd love to see some of your ships!
  10. #8
    Dew
    Dew is offline
    Oct 2015
    Thanks for a simple and effective idea
