Results 1 to 5 of 5
Thread: Third slide for threading on a watchmaker lathe
    Mar 2018
    New England, USA
    threesixesinarow's Tools
    This is my version of K. N. Harris’ “screwcutting device” shown in Model Engineer July 8, 1948. It takes the place of the toolpost on a plain lathe to allow feeding the tool independent of the cross slide in order to cut just with the leading edge while using a threading attachment that drives the topslide.
    His was designed for a 90mm center height lathe. Mine is for a Unimat-sized machine with half the swing of his Boley and even less clearance over the topslide so I had to modify some of the original details.
    The least obvious of these is the key for the barrel which in mine is a staple-shaped piece of 0.056” piano wire flattened in the middle and held in two close fitting holes in the bottom.
    The overall length of my version is about 3-5/16” and the body is 1-3/4 x 1-1/2 x 9/16”. The 3/8” barrel has about 1/2” travel and is split at the end to clamp tools instead of using a set screw.
    I use 3/16” round tools in an eccentric 1/4” adaptor sleeve that allows some vertical adjustment.
  2. The Following 10 Users Say Thank You to threesixesinarow For This Useful Post:
    emu roo (May 2, 2025), Jon (Jul 16, 2018), Okapi (Aug 3, 2018), olderdan (Jul 17, 2018), Paul Jones (Aug 26, 2020), PJs (Jul 17, 2018), rossbotics (Jul 16, 2018), Seedtick (Jul 16, 2018), Stevohdee (Jul 27, 2018), Toolmaker51 (Jul 21, 2018)
