Results 1 to 4 of 4
Thread: Threading - Feeding with the Cross slide vs Compound
    Supporting Member winkys workshop's Avatar
    Apr 2020
    Kentucky
    winkys workshop's Tools
  2. The Following User Says Thank You to winkys workshop For This Useful Post:
    finchie (Jul 9, 2024)
    Thanks winkys workshop! We've added your Threading Method Comparison to our Machining category,
    as well as to your builder page: winkys workshop's Homemade Tools. Your receipt:
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Thanks for that very informative video. Thread cutting is something I try to steer around on my Myford ML7 without a gearbox - setting up the gear train is a pain. I have so far only tried straight feeds on the cross slide and have had reasonably good results, even in the days when my turning skills were in their early stages. (I even managed to cut an extended cross slide feed screw for the Myford extended cross slide which turned out far beyond my expectations).
    Apr 2020
    Kentucky
    I had a Logan with change gears so I understand. I did however do a lot of threading. My next lathe had then QC gearbox, what a difference! It makes me wonder why they would make a lathe without one. With that being said, a lathe with change gears is much better than no lathe!
