3 Attachment(s)
TIG Cooler
Made up a TIG cooler, cut out the body from scrap aluminium sheet, a high pressure low volume pump, a ball valve for adjusting the pressure, cheap aquarium thermometer for checking coolant temp, a pressure gauge for checking pump pressure, radiator coil and fan from an old airconditioner, 20lt alum. tank TIG welded to house coolant. A fused switch for the fan and pump. I added a small shroud for the fan to help with air flow but dont have a pic of it completed.
Thanks Ed.! I've added your Stainless Hammers to our Metalworking category, as well as to your builder page: Ed.'s Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/tig-cooler"><img src="/uploads/45428/tig-cooler.jpeg" alt="TIG Cooler" /></a> </div>
</div>
<div class="title">
<a href="/tig-cooler">TIG Cooler</a> <span> by <a href="/builder/Ed._3">Ed.</a></span> </div>
<div class="tags">
tags:
<a href="/tag/tig">TIG</a>, <a href="/tag/fan">fan</a>, <a href="/tag/pump">pump</a>, <a href="/tag/cooler">cooler</a>, <a href="/tag/switch">switch</a>, <a href="/tag/tank">tank</a> </div>
</div>
</div>
</div>
