Results 1 to 5 of 5
Thread: Tool and cutter grinder stone bushing
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    I bought some cheap diamond stones from China for my tool and cutter grinder but they are supplied without plastic bushings. The wheels are 20 mm diameter and the grinder shaft is ½”. I have been working on a project which needs some special cutters making, so at last I have had to make a bushing so the wheels can be mounted on the grinder. I could have sourced and purchased some but a 20 minute job to make one from steel I couldn’t see the point.
    This is a very simple turning and drilling exercise and will last.
    I have purchased a spin indexer which I will be using to make the cutters so once this arrives I will post the modifications I intend to make to it to mount on the grinder.
    I have also found a great post Homemade Tool & Cutter grinder (with a difference). from Tony Foale on modifications he has made. So a big thank you to him.
    Photos below show bush and grinding wheels
    Diamond wheels
    Tool and cutter grinder stone bushing-img_4552.jpg Tool and cutter grinder stone bushing-img_4553.jpg
    Front and back view of bushing
    Wheel mounted on bush
    In place ready to use
    The Home Engineer
  2. The Following 6 Users Say Thank You to thehomeengineer For This Useful Post:
    baja (Feb 19, 2020), high-side (Feb 18, 2020), Jon (Feb 20, 2020), Scotsman Hosie (Feb 20, 2020), shopandmath (Feb 18, 2020), Tonyg (Feb 19, 2020)
    Thanks thehomeengineer! We've added your Grinding Stone Bushing to our Grinding category,
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Great job
    Do you want to mention where you purchase them
    I had a very difficult time finding dressing stones for diamond wheels
    If you have a source that’s cost-effective I would appreciate knowing it
    Thank you Ray
    Berkshire UK
    Hi Ray
    Thank you for your interest. The wheels are standard wheels you can purchase from EBay. These are suitable for tungsten carbide. I paid £21 for 3 deep cup wheels and £12 for 3 cup wheels. So these are not dressing stones as I think you are after as in dressing a diamond wheel?
    I hope I have this correct
    The Home Engineer
    olderdan's Tools
    Quote Originally Posted by shopandmath View Post
    Great job
    Thank you Ray
    Hi Ray
    This may help. We used a lot of diamond and CBN wheels and they will become loaded and blackened like any abrasive wheels, cleaning was simply an 80 grit white alkoxide stone used lightly freehand. As for truing a new wheel, if properly mounted they are usually pretty good as supplied and will soon bed in with use, this can be hastened buy a few passes over a carborundum sharpening stone.
  7. The Following 3 Users Say Thank You to olderdan For This Useful Post:
    NortonDommi (Feb 28, 2020), shopandmath (Feb 22, 2020), thehomeengineer (Feb 20, 2020)
