I like the idea. I myself have a small shop too, BUT I too have several small benches that are cantilevered off the wall, and stationary in-place, for several different types of work. I have a "Machine Bench" that holds both my Unimats and all the tools with them, as well as a Dremel wall-mounted bit organizer, then to the far right in the corner, I have a "Electrical Bench" for soldering and all that, with a Weller and bench top placement, then to the right of that is my "Train Bench" which is where a lot of the tools I use for working on my scale model trains is done, with a Electrical Tester stand. Then around the Chimney I incased the corners of with strapping lumber I have a small 16 by 24 inch "General Bench" where I do most of my Model car work.... Only actual Tool it has near it is a Dremel with Flex Shaft suspended from the ceiling that operates by a variable speed foot pedal on the floor. Behind me in that area is my "Molding Bench", that has but a digital Scale for weighting Resin plastic and then to the right of my General Bench is a Aux Bench (I call it my "Paint Bench"), due to it having the Air Brush Compressor mounted under it, and a cabinet above it housing all sorts of paint rattle cans, and other painting supplies, down that same wall goes to my Wife's Craft Bench, and up the wall to her right is a "Drying Bench" by the window, and then up and coming (I have yet to build) another small bench into the corner where I once had a small Shop refrigerator to house chemicals, like Lacquer, and thinners of all sorts as my shop gets hot in the summer, that kept them cool, but it went up this winter and has been removed, and a roll around cooler took its place and that wall there in the corner will be another bench this summer. Down the wall from that your back at my "Molding Bench" and to the right of it, in the other corner is my "Shop Computer Bench" which has my offline Shop Database Computer there, and to its right, your back at my Machine Bench....
Question guys, where can I post pics of my shop to show all of this? -That way when I speak of it those who read my posts have an idea of how my shops laid out...
