Results 1 to 5 of 5
Thread: THIS TOOL WILL HELP metal workers and if you WORK WITH WIRE crimper BEVEL MAKER
Hybrid View
    Supporting Member Sleykin's Avatar
    Oct 2017
    Medford, Oregon USA
    Sleykin's Tools
    I was an electronics tech for 36+ years. I installed and maintained NAV/RAD/COM equipment the whole time. I absolutely hated crimps. I was required to use crimps on many of the com stuff. Frequently a problem. I did use swaging tools on large solid connectors. For large, stranded wire, I us solder and maybe a crimp to start. For automotive type wiring I do use crimps with a properly adjusted ratcheting crimper. Marine grade heat shrink tube goes over the connections if they are outside things.
    Be careful with RTV around electrical connections. Most RTV has acetic acid in it that outgasses as it dries. This will cause corrosion inside the connections. There is a special RTV made for electronics, and it will say safe for electronics.
    Sorry I am so late to the party LOL
  2. The Following 2 Users Say Thank You to Sleykin For This Useful Post:
    emu roo (Jul 21, 2025), Saltfever (Jan 25, 2025)
