Results 1 to 8 of 8
Thread: Tractor gear shift cover cup.
    A Ford 2600 arrived last night for a temporary swap for my Case 431
    Both tractors are near equals in power output but the Ford is lighter and shorter also a foot lower in height.
    My case has a medium duty 6 ft shredder mower, the Ford has a much heavier duty 5 ft brush hog shredder mower.
    The Ford has foam filled front tires, something that is appreciated in the mesquite brush I need to cut.
    However the ford had a gear shift problem we noticed while unloading it and there was water contamination in the transmission oil.
    the gear shift lever just needed a bit of weld build up to fix that problem, And while I had it apart I decided to cure the water getting in the transmission problem by making a new cupped cover to replace the missing one on the gear shift lever.
    I started with a fat of about 1/8" thick heated it up and bet it to about 1/16" thick then heated it up and shaped it into a cupped shape with the punch and die I made for that purpose
    I pushed a rubber sleeve down onto the shaft
    the factory spring keeper forces the shift lever to stay in place but the added rubber sleeve will further prevent water contamination
  2. The Following 5 Users Say Thank You to Frank S For This Useful Post:
    baja (Sep 30, 2021), metric_taper (Sep 29, 2021), NortonDommi (Oct 1, 2021), nova_robotics (Sep 29, 2021), rlm98253 (Oct 3, 2021)
    Marion, Iowa
    metric_taper's Tools
    You would be a great person to loan stuff too, as it would come back in better condition then borrowed.
    Nice fix.
    I see the other post of the die.
    Nice fix.
    I started puling the front axle off today because the center pivot bushing is so far gone the the tractor has about 4 inches of castor. So much that the control arms are bent
    Thanks Frank S! We've added your Tractor Gearshift Cover Cup to our Transmission category,
    North Island, New Zealand.
    NortonDommi's Tools
    The number of old tractors I have seen with deteriorated/missing boots on shift levers an water/oil foam filled transmissions/hydraulics is numerous. Gives a good indication of how often some people check fluid levels.
  7. The Following User Says Thank You to NortonDommi For This Useful Post:
    Frank S (Oct 1, 2021)
    Quote Originally Posted by NortonDommi View Post
    yeah ya think.
    I called the guy and asked him when was the last time he had changed the engine oil, all I got was dead silence on the phone for a couple minutes.
    never mind I told him.
    Judging by the condition the front axle was in I figured all he had done since he bought the thing 4 years ago was to use it a few times a year to mow with and had possibly not done anything other than put a battery on it in all that time
    NortonDommi's Tools
    Been working on a friends stuff off and on for a while now, Lived a life devoid of mechanics apart from driving a car, bought a lifestyle block and some clapped out machinery,(got ripped off too),and the learning curve is steep.
  10. #8
    Some friends of mine have had to go through some very steep learning curves themselves simply because they don't know what they don't know, and are either too proud, too embarrassed, too arrogant, too ashamed or possibly too stupid to ask someone for advice. Although I hesitate to call any of my friends stupid, Insane yeah, but not stupid, as we all at one time or another have made that one mistake when we slap our heads and say well dummy how do you get yourself out of this stupid predicament.
