Thread: Tractor rear end loader - video
    Tractor rear end loader. By Scott Turner. 22:39 video:
  2. The Following User Says Thank You to Jon For This Useful Post:
    nova_robotics (Feb 17, 2022)
    Feb 2015
    Just a thought-a lot of earth moving equipment used cable winches to raise and lower buckets, blade, gannons, etc.
    Nice job from Up Over (California).
  4. The Following User Says Thank You to Pa1963 For This Useful Post:
    NortonDommi (Feb 19, 2022)
    North Island, New Zealand.
    NortonDommi's Tools
    A properly designed FEL doesn't put the load over the front axle and without the ability to tilt this can only be used on a horizontal surface or up hill.
    Oct 2016
    old kodger's Tools
    Quote Originally Posted by NortonDommi View Post
    I have a Yanmar YM165 somewhat smaller than this one, but there is enough "hydraulics" to put a small ram in place of the turn buckle which would give a limited amount of tilt.
    I have one similar to this. I can drag it to fill or turn it around and push to fill.
    I used one a lot as a kid to dig stock ponds with. Pushing to fill is not the best way to use them, even without tilt they have a tendency to try and dig in too deep. Optimally you want the bucket nearly level to the ground and just scrape very shallow cuts. If they are made right there will be a secondary top link with a latch that allows the cutting edge of the scoop to make the cut then unlatch the secondary link when raising and it will tilt back some to hold the material in. once you get where you are going release the dump latch
