Results 1 to 4 of 4
Thread: Transverse drilling attachment V2
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    I already showed my side drilling system on the lathe :
    Homemade Transverse Drilling Attachment
    This first version has the drawback of having a too big chuck and too long attachment sleeve behind it so that it really works only with short bits.
    I recently found a new kind of smaller chuck and imagined a way to attach it at the end of a shaft with the bare minimum additional pieces.
    Here is how I did it :
    The mandrel is a small three jaws mandrel to be used on a power screw driver. It is quite precisely made.
    It has an Hex shaft. Here is how I imagined attaching it at the end of my 12 mm shaft. I simply drilled a side hole in the 12 mm shaft like if I wanted to use a set screw.
    But instead of using a set screw, I just filled the hole (two sides) by welding a little spot.
    In order to avoid any projections, I wrapped the chuck and shaft with a piece of aluminum sheet.
    I then cleaned up the welded joint on the lathe to get a smooth surface on the shaft.
    Here this is the little fixture I use on the metal lathe QCTP. You can see that the chuck can be pulled back
    much more than on the previous version.
    And here on the wood lathe :
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 4 Users Say Thank You to Christophe Mineau For This Useful Post:
    Jon (Apr 8, 2016), Paul Jones (Apr 9, 2016), PJs (Apr 8, 2016), scoopydo (Apr 9, 2016)
    Thanks Christophe Mineau! We've added your Transverse Drilling Attachment to our Drilling and Drill Presses category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice Christophe. Now with your indexer you are set to go! Thanks, ~PJ
    Mark Twain
  5. The Following User Says Thank You to PJs For This Useful Post:
    Christophe Mineau (Apr 9, 2016)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Christophe,
    Great idea about the wielding the part through the two small holes. Nice to see your cross drilling and indexer projects.
    Thanks, Paul
  7. The Following User Says Thank You to Paul Jones For This Useful Post:
