Thread: Trying not to kill myself
    Jan 2018
    New here, just a thank you for the forum and to all that post, comment and just shake your head at what you've seen. Several projects to do, staying on track and doing just one at a time is the hardest part
    Hi Wooden_Nickel - welcome to HomemadeTools.net
    What's next up on your build list? Let me know and I'll post some links for ideas.
  3. #3
    Jan 2018
    Too many things to remember but some of the first things are the Gingery lathe. I'm currently using sketchup to design some if not all the parts, did one ball crank this week. I have all the parts but haven't assembled a burner for a foundry, still need to weld the foundry up yet also. This is the start of this year rest of goals in roughly most important to least
    Rocket Mass Heater - To heat garage for next winter built a metal J-Tube which just didn't work as well as it should. So redo that with a better fire brick
    construction
    RV ramps - To get the RV (biggest project) level so I can work on and get that to where I want it to be. Driveway has a pretty good incline
    RV - Steampunk themed but not to use as an actually RV but someplace quite to work on pc most needs complete rewire and new roof, floor and computer desk.
    It's currently gutted but also going to redo entire dashboard area.
    1953 Chevy - needs to run, windshield, heater core, and rewire this year, body/rust and interior next year thinking for trying a car rotisserie
    CNC plasma cutter - Hopefully this year want a 4x4 table
    Welding/Grinding room - Built a 6x10 room out of old lockers from work in garage for the CNC plasma, grinding and cutting tools. Still needs roof and doors to be
    welded on and exhaust duct to be installed then shelving and any stands
    Forge -
    Foundry - Where I work I get a lot of brass, copper, and aluminum using this for RV hardware and designs also everything for the Gingery lathe
    Work bench - Built a L-shaped 9x8 bench last summer want to set table saw into it along with jigsaw, router, bandsaw and put some clamps and vises built into it
    Tools I want to make this year are:
    Lathe
    Belt grinder
    Bandsaw
    Sheet metal brake
    Welding table
    Hopefully these links work
    https://imgur.com/gallery/762If rocket mass heater
    https://imgur.com/gallery/O9PMH welding/ginding room
  4. #4
    Lockers made into a wall = clever! You'll fit in well here.
    Here are some links for ideas for the tools you want to make this year:
    Homemade Lathes - HomemadeTools.net
    Homemade Belt Sander
    Homemade Bandsaws - HomemadeTools.net
    Homemade Brakes and Presses - HomemadeTools.net
    Homemade Welding Tables - HomemadeTools.net
  5. The Following User Says Thank You to Jon For This Useful Post:
    Wooden_Nickel (Feb 6, 2018)
    Before opening link, lockers forming a work enclosure gave me a different mental picture. Great reuse of sheet metal, turns out even bigger surprise.
    Still has me wondering, I have two walls, a corner of brick to enclose. Had planned as grinding area, keeping airborne grit isolated from machinery. The flame proof aspect of metal worth rethinking.
  7. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Wooden_Nickel (Mar 21, 2019)
