Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Twin 30" Belt Sander/Grinder
    Supporting Member Carlos B's Avatar
    Canada
    Carlos B's Tools
    In keeping with my previous post "Dual Fuel Furnace", this is my latest casting project. I took a cheap underpowered 6" grinder and converted it to a twin 30" belt sander/grinder. It has lots of power in this format and is very usefull around the shop, shaping,sanding and grinding small wood and metal parts. The V rest does a good job of cleaning and touching up drill bits and other small tools. Here are some pictures of the construction including all the pre-assembly parts.
    For complete build documentation visit my site at the following link:
    Hobby Workshop Projects
    Cheers Carlos B
    Attached Thumbnails Attached Thumbnails Twin 30" Belt Sander/Grinder-68.jpg   Twin 30" Belt Sander/Grinder-9.jpg   Twin 30" Belt Sander/Grinder-15.jpg   Twin 30" Belt Sander/Grinder-36.jpg   Twin 30" Belt Sander/Grinder-46.jpg
    Twin 30" Belt Sander/Grinder-29.jpg   Twin 30" Belt Sander/Grinder-31.jpg   Twin 30" Belt Sander/Grinder-52.jpg   Twin 30" Belt Sander/Grinder-57.jpg   Twin 30" Belt Sander/Grinder-62.jpg
    Twin 30" Belt Sander/Grinder-64.jpg   Twin 30" Belt Sander/Grinder-66.jpg   Twin 30" Belt Sander/Grinder-67.jpg   Twin 30" Belt Sander/Grinder-69.jpg   Twin 30" Belt Sander/Grinder-70.jpg
    From a popular rap: "If time is money then I need a loan."
    Carlos B,http://hobbyworkshopprojects.blogspot.com
  2. The Following 23 Users Say Thank You to Carlos B For This Useful Post:
    Alan Purdy (Mar 23, 2019), aphilipmarcou (Mar 17, 2017), baja (Sep 1, 2023), blkadder (Mar 13, 2017), bvd1940 (Mar 13, 2017), Captainleeward (Feb 12, 2018), Corm (Feb 5, 2018), Home-PC (Aug 31, 2023), jjr2001 (Feb 8, 2018), Jon (Mar 11, 2017), JTC (Jun 23, 2019), kboy0076 (Sep 5, 2023), mattthemuppet (Mar 24, 2017), mwmkravchenko (Jun 12, 2018), nova_robotics (Aug 31, 2023), olderdan (Mar 13, 2017), Paul Jones (Mar 11, 2017), Priemsy (Oct 9, 2018), rlm98253 (Mar 13, 2017), rossbotics (Mar 12, 2017), Scotsman Hosie (May 8, 2019), tonyfoale (Mar 17, 2017), volodar (Oct 10, 2018)
    Thanks Carlos B! We've added your Twin Belt Sander to our Metalworking category,
    as well as to your builder page: Carlos B's Homemade Tools. Your receipt:
    Carlos B (Mar 13, 2017)
    Dec 2013
    Florida
    rossbotics's Tools
    Hi Carlos
    You done a great job, very well executed, keep up the good work
    Comments are always welcome
    Doug
  6. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    Carlos B (Mar 13, 2017), olderdan (Mar 13, 2017)
    Canada
    Carlos B's Tools
    Thank you for the positive feedback rossbotics.
    bvd1940's Avatar
    Oct 2012
    one heck of a nice job, now I gota build one lol
    Bill in SE Idaho, Given enough incentive and proper motivation anything can be fixed
  9. The Following User Says Thank You to bvd1940 For This Useful Post:
  10. #6
    Supporting Member mr95gst's Avatar
    Apr 2014
    Murfreesboro, TN, USA
    mr95gst's Tools
    That is fantastic and inspiring! Did you have to mill the back of your castings flat or lots of sanding? Your finished pieces look clean and uniform. I always struggle with making a uniform appearance with my finished castings. I usually end up machining every surface because I haven't found a good way to blend a cast finish into a machined surface without it looking odd. Whatever you did looks good.
  11. The Following User Says Thank You to mr95gst For This Useful Post:
  12. #7
    Canada
    Carlos B's Tools
    The castings had a reasonably good finish coming out of the mold, just a couple of shrink spots. The castings got a good wire brushing and some filing to blend in a few rough spots. Aluminum is easy to work so I sanded the flat side on a 12" disk sander for a nice flat finish. The mounting collar did get bored out for a close fit to the grinder housing.
    Carlos
  13. #8
    Jul 2015
    South East Wales UK
    That's really neat, I trust you have different grit belts, a very nice piece of equipment to have in your workshop. I might make one to use for sharpening my wood turning gouges.
    Cheers John
  14. The Following User Says Thank You to John Durose For This Useful Post:
  15. #9
    Canada
    Carlos B's Tools
    Thanks John, Yes I went with the 30" because the belts are easily available in any hardware store and relatively inexpensive. The duel belt design was attractive because you can go from coarse to fine instantly. Yes I have touched up my turning chisels and numerous other tools on it. Its quick and easy to set up.
    Carlos
  16. #10
    Jul 2015
    South East Wales UK
    I currently sharpen my wood turning tools on an eight inch whetstone which gives me a hollow grind which has its advantages however there appears to be a move to flat grind with some commercial grinders on the market. I must say I enjoy the challenge of making my own tools and jigs related to wood turning. I am not into casting but I am sure I can fabricate a successful system.
    Have fun!!
    John
