Yes I understand most people don't have the equipment to cast. I got my inspiration for this project from a George Barnes plan which he has made free for distribution. A full plan set is available on the "Projects In Metal" site. His plan is all steel construction and is for a 2"X42" sander/grinder. 42" belts are hard to source some builders have redesigned to 48". For my design I went with a main casting and 30" dual belts so many changes were needed. I also modified the tension and tilt assembly. So a non caster should be able to produce a similar machine.
Carlos
