Results 1 to 7 of 7
Thread: Un-child proof bottle caps
    Lake Tahoe
    IntheGroove's Tools
    If you don't have children in your house and want an easier way to open your pill bottles just but a short screw in the cap. I've been doing this for years...
  2. The Following 7 Users Say Thank You to IntheGroove For This Useful Post:
    Altair (Sep 15, 2022), emu roo (Apr 30, 2026), Inner (Sep 15, 2022), katy (Sep 16, 2022), Miloslav (Sep 15, 2022), mr mikey (Sep 15, 2022), uv8452 (Sep 16, 2022)
    PDXsparky's Avatar
    Nov 2018
    Nice, simple solution. I've been taking the caps to my band saw and making a couple cuts just deep enough that I can remote the outer cap and keep the inner cap that screws onto the bottle.
  4. The Following User Says Thank You to PDXsparky For This Useful Post:
    Lake Tahoe
    IntheGroove's Tools
    You can use the same screw over and over or use the same cap over and over...
  6. The Following User Says Thank You to IntheGroove For This Useful Post:
    Why go to all the trouble? just a couple drops of super glue or even fingernail polish between the inner and outer caps at the rim and they are bonded for ever just be sure and let dry before putting it back on the bottle
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Thanks, I'll give that tryers next time I get a new bottle of meds.
  10. The Following User Says Thank You to katy For This Useful Post:
  11. #6
    Quote Originally Posted by PDXsparky View Post
    Like you, I remove the outer cap and use the one that does the real sealing. I too had used a saw but I discovered that if I used my Xuron sharp tip wire cutters to put two opposed cuts in the rim of the outer cap I could snap it in half with my fingers, releasing the inner cap.
    There are other designs for safety caps. Some have cap ratchets that snap into projections on the bottle. Releasing them requires squeezing or otherwise distorting the cap. Again, wire cutters used to amputate the bottle projections work well.
  12. The Following User Says Thank You to mklotz For This Useful Post:
  13. #7
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    I have used hot glue on these caps. All the solutions are interesting and proves that not all that many children are around all over.
  14. The Following User Says Thank You to Hans Pearson For This Useful Post:
