Results 1 to 6 of 6
Thread: Understand a Rotary Table with Top Cross Slide
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    A master machinist friend of mine, Gerry Goldberg, presented a talk on how to use a rotary table with a top cross slide. This is not to be confused with a rotary table with bottom cross slide. I took lots of notes and wrote this article:
    http://rick.sparber.org/rtcs.pdf
  2. #2
    Good information, Rick. Something to mention to my machinist friends.
  3. #3
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    With so much CNC being used, the old methods like compound rotary tables have fallen out of favor. Yet it is amazing what can be done with these attachments.
  4. #4
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Rick,
    Thank you for documenting the basics and explaining the logic for this type of XY table configuration with a rotary table. It is easy to get confused so sometimes I write on the table and dials with a marking pen to show which way is in-out, right-left relative to the milling tool and rotation. I have not tried manually machining curved spokes on flywheels but like your article on milling openings, I have read the techniques and would probably do it the first time in wood or plastic to make sure I really understood the movements.
    Thanks for publishing this (and adding the Copyleft protection for sharing),
    Paul
  5. #5
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    You are most welcome. Yes, it is certainly easy to get turned around with all of these motions. Testing out with wood is a very good idea. In CNC, they often use "machine-able wax" to test out the program. Saves a lot of tool crashes.
  6. #6
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    This thread has been moved to the Must Read subforum. Congrats (and thanks) to Rick for making such a valuable contribution!
